Thread: What to do about liner bleaching?
    gazumph's Avatar
    Jun 2015
    Spartanburg, SC
    3
    Liner is bleached in some big spots. What can I do about the bleached areas?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: What to do about liner bleaching?
    There really isnt much you can do about a liner that is already bleached or faded.
    Liners are "printed" with dye and once the dye is faded, then its done.
    Isolated spots of fading are generally caused by a concentration of chemicals in that area. Likely the result of adding liquid chemicals too fast or adding them in an area with poor or no water circulation.
    In the future though, you should be able to prevent that by adding liquid chemicals by pouring them very slowly in front of a return and let the pump continue to run for at least 30 minutes after adding them, so they get mixed well in the pool.
    Divin Dave,
    30,429
    +1 what divin dave said.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Pretty much your only option is a new liner, since you can't restore the color once it is faded. The next question is figuring out if it has faded pre-maturely and if the way you or a former owner added the chemicals caused the fading.
    Love TFP? Become a
    TFP Supporter!
    22,553
    While it may be bleaching, it could also just be fading. One whole section of my liner is lighter than the rest from seam to seam.
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    My liner faded a little after an aggressive SLAM. It's not as "blue" as it was before, but it still functions perfectly and I'm not worried about it. A slightly lighter liner is better than green cloudy water!
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
