Results 1 to 7 of 7
Thread: Pebble Tec turned white
    Aug 2015
    Scottsdale, AZ
    3
    I treated algae stains on my pebble tec surface by letting granular shock sit on the stain.
    It killed the algae, but left a white stain that I cannot remove with a wire brush.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pebble Tec turned white
    Welcome to TFP!
    I'm sorry to say you will not be able to "remove" the white stain as it is now a place where all color has been bleached out of the pool surface. Think of splashing bleach on a colored pair,of pants, it takes the color away permanently.
    You should never let pool chemicals sit on the surface of the pool or damage can occur.
    Support the site
    38,248
    Welcome to TFP!
    Have to agree with Tim, sorry you did not find us first.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, that's what happened, and I wish I could disagree with the above. Sorry to hear it for you.
    Essential Links:
    Jul 2011
    Arizona & California
    803
    I have a question. Is it just the cement portion between the pebbles that has turned white, or does the white also cover the pebbles too?
    Aug 2015
    Scottsdale, AZ
    3
    Thanks to all.
    The white stain does not appear to be on the pebbles. Interestingly, as I use a wire brush, it creates a white cloud.
    Jul 2011
    803
    That is interesting and confusing. If the white stain is not on the pebbles, that would indicate that the chlorine shock "bleached" out the color pigment of the cement portion of the surface finish.
    However, you also indicate that a white cloud develops when brushing. So that indicates calcium scaling on the cement portion, which is possible because "granular shock" is usually Cal Hypo which contains calcium.
    So a close-up picture or two would be beneficial. Can you post a couple of pictures? I am very curious about this.
