Thread: Pool gasket glued
    Aug 2015
    Lincoln Nebraska
    1
    Pool gasket glued
    I have a pentair multivalve that the gasket needs replacing. This thing is totally glued down. I've looked up videoes where people just peel it right off. Am I doing something wrong? Picture attached. Thanks in advance!!
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    Re: Pool gasket glued
    I have one of those too, and it should come right out. It seems like a problematic part though, as I have had to use some glue to keep mine in place.
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Looks like the previous owner or service shop was over zealous in applying Super Glue in the prior install and figured they would not be the next person changing the gasket out. Sorry about your predicament here I have been putting off replacing mine because if it the prior owner ever replaced it, I am certain this is what I will be looking at too.
    Small line of RTV sealant down each channel or minimal drops of Super Glue should be all that is needed. One pool store even told me to use regular rubber cement from the school supply aisle.
    Good luck with this.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
