Results 1 to 8 of 8
Thread: Let pool settle before installing hayward skimmer?
    Jun 2015
    Mesa, AZ
    16
    Starting to install my 22' intex agp tomorrow and ordered a couple goodies to go along with it. The 3000 gph intex sand filter and pump & the hayward skimmer. Should I wait a week or so before installing it(skimmer that is)? Id hate to install it right away and have the holes stretch out a tad and cause a leak. I live in AZ by the way.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Let pool settle before installing hayward skimmer?
    Yes, I will wait a little, in my case was two months, but I hated all the insects floating in my pool, so go for it and install sooner than me, good luck
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP! Congrats on the new pool!
    30,431
    Your pool should be stretched and fitting fine just as soon as you get water in it. No need to wait. I am not too familiar with Intex setups but my guess is you will want to work from inside the pool some.
    I would fill it half way, get in and go to work. Keeps your feet cool, too!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,553
    I agree with Dave, no need to wait. I drained mine just below the bottom of the skimmer before cutting it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    Mesa, AZ
    16
    Thanks for the replies everyone. In the middle of getting the yard set up. Hopefully this weekend I can start filling up
    Jun 2013
    Fallsburg, NY
    258
    Yes, no need to wait. I installed mine during the first fill up when it was about half full.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    May 2012
    Las Vegas, NV
    92
    take your time when mounting the skimmer and careful cutting the vinyl. I had minor leaks on each side of the gasket and had to use clear silicon which took care of it. At some point i'll put a new gasket (winter) and won't cut it this time.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
