Thread: Chlorine in a bromine pool.. good or bad?
    Aug 2015
    Cleveland/Ohio
    1
    I'm a fairly new pool owner but I have been using the forum for help but can't find much information to help my current problem. Recently my pool was clear and all of my levels were fairly in range except for the Bromine. My Bromine was low and I was battling it with my brominator turned to high. The tabs were dissolving but there was nothing showing on my DPD test. Bromine was zero. So I read a researched that you can activate the bromine with liquid chlorine.is that correct? If not then I screwed this up. I added chlorine a few days ago but it turned my clear blue water a cloudy bluish green color. I ran my pump for a few days and no change. Then I read that it must be metals in my water so I added a bottle of Metal Free last night and still no change. How can I get back to clear water? Also, I battle with my bromine is there a way to quickly increase the bromine levels?
    Br-0.4
    pH- 8.0
    CH - 200
    TA - 120
    pool store values are the similar as my test but they said my bromine was zero and my phosphates are at 1000 and copper and iron are zero
    Any help would be appreciated since this is my first post
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Chlorine in a bromine pool.. good or bad?
    Welcome to TFP! Congrats on the newish pool!
    I do not know a thing about bromine. But, I do know where this handy article about bromine is in Pool School.
    How do I use Bromine in my spa (or pool)?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Well me to TFP same here I don't know a thing about bromine but I'm surely learning here
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    If you have either initially added a bromide bank (i.e. added sodium bromide to the pool) or have been using bromine for a while so spent bromine will have built up a bromide bank, then yes if you were to add chlorine or any other oxidizer to the pool (i.e. non-chlorine shock, ozone, etc.) then it will reactivate the bromide to bromine.
