Thread: New Salt Water Pool Conversion
    Aug 2014
    Florissant, MO
    7
    Question New Salt Water Pool Conversion
    Hi - I have just converted my pool to salt water and installed an Intex SWG. I know from pool math what the ranges are but can anyone give me the ideal pool settings for my chemicals? My ideal FC according to my generator should be around 3000 (Rng is 2500 - 3500). Thanks~
    1998 Doughboy 16x28x3.5 Oval AG pool (10,300 gallons)
    Hayward Power Flo Matrix pump w/single speed-1 hp motor & Hayward EC-50 DE Filter
    Use Aqua-Check Reg & Salt Test Strips / Taylor K-2006 & TF100 / Speedster Magnetic Stirrer
    Just added Intex SWG w/ECO 8110 (15000 gallon) Pool owner since 1978.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Re: New Salt Water Pool Conversion
    Our recommended levels are here: Pool School - Recommended Levels
    The only thing not on that chart is your FC level, which will be based on your CYA level. That chart is here: Pool School - Chlorine / CYA Chart
    Is everything good from the algae problems you had last year?
    Support the site
    Aug 2014
    Florissant, MO
    7
    Thank you Tim5055.......That chart is exactly what I needed, but I didn't receive a location of the FC/CYA chart?? I was a little confused by the Pool Math calculator as on the CH it showed a goal of 50 - 300 but a target of 260??? And the CYA, a goal of 70 to 80 but a target of 40? Etc....
    May 2014
    Franklin, NC
    9,205
    Quote Originally Posted by 1buccaneer View Post
    you have a vinyl pool. Ignore CH. you don't want to add any.
    As to Pool Math be sure to set the yellow section at the bottom to goals for Trouble Free Pool, SWG & vinyl. That should clear up the goals.
    Support the site
    Aug 2014
    Florissant, MO
    7
    I found it Tim5055 under the Handy References, exactly what I needed........Thanks again......
    Thank you.....good to know as mine is at 60 and I've never fooled with it before and wasn't loking forward to raising it a lot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Here is a specific saltwater page with some more details. Pool School - Water Balance for SWGs
