Thread: Bubbles off of ECO electrode
    Aug 2015
    Bartlesville, OK
    2
    My Intex SWG system has been operating well and then I cleaned the cell the other day and ever since, it cannot keep up at all. The water is turning green to no end. I did notice that the ECO electrode, which used to have bubbles streaming off of it during operation no longer does. Thoughts?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Bubbles off of ECO electrode
    Call Intex costumer service, if your swg is still in warranty they most probably send you a replacement, good luck
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    38,475
    You should be supplementing the FC with bleach if you know the SWG can not keep up to prevent the algae from starting.
    Sounds like you need to follow the SLAM process now.
    Jul 2015
    Virginia Beach/VA
    3
    I can say that if your pump/pool is still under warranty, I found Intex customer service to be very responsive. I had a dead pump gauge, a broken flow tab, and dead SWG electrodes, and they forwarded all of the necessary replacement parts promptly. I also found the replacement of those parts to be very intuitive. Good luck!
    Jim & Leslie Pasch
    Intex Ultraframe 18'x9'x52" AG (6900 gal)
    Sand filter Pump & SWG (Intex Model ECO 15110)
    Install date: 11 July 2015
