Results 1 to 14 of 14
Thread: Output Percentage for run-time vs powerd-on time
    Jun 2015
    Eastvale, CA
    15
    I have a Pentair SWG and am working on dialing in my percentage and runtime. I currently have have it set at 80% and run my pump @ 1700 rpm for 6 hours. I run another 6 hours @ 1000 rpm for circulation. During the 1k rpm cycle, the SWG reports "low flow" which is expected. From my understanding, no chlorine is being generated at this time. Is the 80% being calculated for the entire time the SWG is powered on (ie. 12 hours in my case) or for only the 6 hours where I have a high enough flow?
    I have a feeling it is for the entire powered on time because I was originally running for 8 hours @ 1700 rpm and 4 hours @ 1000 rpm and after lowering that there has been no change in my FC levels.
    Matt
    ~12.5K gal 10'x40' IG pool + attached spa, StoneScapes Mini-Pebble
    IntelliFlo VS (main), WhisperFlo 2HP (spa), SuperFlo 1HP (waterfalls)
    Pentair FNS Plus DE filter 60sq, EasyTouch w/ SWG, Dolphin Z5 Robot
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Output Percentage for run-time vs powerd-on time
    Why? The first 6 hours should be more than enough run time for just circulation. In fact, 2 hours is more than enough for just circulation.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I run mine at 1100 rpm and it keeps my SWG happy flow wise. I would think, but do not know, that the 80% should only count when it is generating. I would dial in something at 1100-1200 rpm, or whatever makes the SWG happy, and run it 6-8 hours or so.
    Jun 2015
    Eastvale, CA
    15
    Thanks for the info. I figured running at such a low rpm wouldn't hurt anything considering it uses very little electricity. My SWG wasn't happy until about 1600 rpm flow wise so maybe I need to clean my filter so I can run at a lower rpm. I am still curious about the percentages being calculated based on total generation time or powered on time.
    I have cut out running the additional 6 hours @ 1k rpm for now and am running 6 hours @ 1700 rpm with the SWG at 60%.
    Matt
    mas985's Avatar
    Pleasanton, CA
    11,741
    The Intelliflo will still use around 150 watts @ 1000 RPM which is 27 kwh over a month so not completely insignificant.
    I believe it is based on total pump run time regardless of the flow switch state.
    Mark
    Jul 2013
    Waxahachie, Tx.
    446
    The 60 or 80% would be 60 or 80% of the run time of the swg being. That slso depends if thete good flow to satisfy that circuit
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    mas985's Avatar
    Pleasanton, CA
    11,741
    From the manual page 8: http://www.pentairpool.com/pdfs/Inte...tor520589J.pdf
    The five (5) LED indicators display as a bar graph to show in 20% increments, the percentage of time the chlorine is produced per hour of pump run time.
    However, technically, the SWG should always turn on and off with the pump. Again per manual instructions page 4.
    Mark
    Jul 2013
    Waxahachie, Tx.
    446
    Of course the swg should be on when pump is running. The issue as i understand is 2 different pump speeds programed. The slower speed not satisfying the flow switch.
    Technically swg %out is based on run time. 8 hrs run time at 50%output would be 4 hours of chlorine being produced.
    JoyfulNoise's Avatar
    May 2015
    13,232
    Quote Originally Posted by rmturner54 View Post
    The manual does not say if a flow switch interruption (low flow) resets the internal duty cycle timer that controls the chlorine output. I think you would have to call Pentair Tech Support to find out exactly.
    If the flow switch does reset the duty cycle timer, then that would be a poor design since you could potentially operate the IC unit right on the edge of the minimum flow rate and cause the unit to keep cycling its chlorine production timer back to 00:00. It would make the most sense to simply have the flow switch interrupt the chlorine generation but not the timer that measures the duty cycle.
    Of course, those are details you'd have to get from Pentair. Proper operation of the cell would be to ensure a pump speed that always supplies enough flow during the times you want the unit to generate and to not operate at a flow rate so low that you would inadvertently trip the sensor.
    Matt
    Jul 2013
    Waxahachie, Tx.
    446
    I was not meaning the interuption of the duty cycle. I was just using the 8hr 50% run time as an example.
    I would think that the unit would only count actual production time. I would think that it would not count any time the unit was not producing due to a flow fault. However, I don't know for sure.
    Support the site
    Jul 2013
    Waxahachie, Tx.
    446
    Let me start over here. I have a Hayward unit. I believe most swg unit operate in a like fashion. The point I was trying to make, is 50% is 50% any way you want to slice it. Lets take the same 8 hour run time and a 50% output setting. That calculates to 4 hours of total chlorine production. Now lets say during the same 8 hour pump run time that the flow switch stops working for whatever reason for 1 hour. The Swg panel does not know that the pump is still running. It uses the input from the flow switch to tell the swg panel that it's running. Therefore you now have 7 hours divided by 50%=3 1/2 hours of total chlorine production.
    This is how Hayward tech support explained this subject to me last year on a phone call.. I could be wrong about the Pentair unit. I would like to know what Pentair has to say.
    Jun 2015
    Eastvale, CA
    15
    Thank you all for the great input. I think if it calculated on a per-hour basis vs. a total runtime then it would work fine unless you happen to run at a low rpm for less than that hour minimum.
    Jul 2013
    Waxahachie, Tx.
    446
    I have a variable speed pmp. I run 1200 rpm and 60% output. No issues with flow sw at 1200 rpm. I have never actually tested to see what speed my quits functioning at
