Thread: PebbleSheen Replaster - Salt startup
    Jan 2014
    Dallas, TX
    68
    Hi guys, completed a pebblesheen replaster about 6 weeks ago. Thanks to TFP, my test kit and lots of testing my water chem is dialed in. Now it's been 30+ days and finally time to add salt! I haven't seen any particular startup instructions for salt in this forum so I'm asking here. The PebbleTech rep was out to the house and she gave me the instructions below.
    Appreciate feedback!
    DAY BEFORE SALT ADDITION
    Backwash, add DE
    Test pool water. Adjust the following parameters:
    Free chlorine to at least 2 ppm
    Lower pH to about 7.0 – 7.2
    Just make sure the rest are within the following:
    Total alkalinity 90 – 110 ppm
    Calcium hardness 180 – 250 ppm
    Cyanuric acid 30 – 50 ppm
    Also add 2 quarts of Jack’s Magic Purple Stuff. Brush the whole pool. Leave equipment running 24/7.
    DAY OF SALT ADDITION
    Check pH and make sure it is 7.0 – 7.2
    Add salt (preferably granular form) and no more than 2 – 3 bags at a time.
    Brush until dissolved and add 2-3 more.
    Only add about 2/3 of what is recommended. Brush until completely dissolved – leave equipment running 24/7.
    NEXT DAY
    Test water for Free chlorine, pH and salt ppm
    Make adjustments as necessary, first to chlorine then pH and then finally add salt (if needed) run 24/7.
    FOLLOWING DAY
    Retest to verify proper readings. Reschedule pool to run normal schedule. You still may need to test
    daily for the next 2-3 days to get the chlorine regulated to the proper percentage.
    26,000 gal / in-ground SWG (Hayward T-CELL-15) / Blue Granite PebbleSheen / 2hp WhisperFlo pumps (main), 1.5hp WhisperFlo pump (waterfall) / Pentair DE filter / AquaLogic control / Polaris cleaner aka "Trackie" / Dallas, TX
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: PebbleSheen Replaster - Salt startup
    I would skip the sequestering agents (Jack's Magic stuff) unless you know you have metal problems in your water. There's no need to add it if you don't need it. If you are on city water, odds are good you do not have metals in your water. Take a sample to your pool store and have them verify since most of us probably don't have metal detection tests on hand.
    FWIW, I'm at day 23 from fill-up of my Pebble Sheen finish (Blue Granite like you...came out a little more grey than I expected but we like it). Did your surface get acid washed prior to fill-up? If so, you probably don't have anything to brush. I brushed a bit at the beginning but didn't see the point of it so I stopped.
    All the levels sound fine to me although I don't think I'd go below 7.2 on the pH. General instructions also sound fine.
    How has your pH been doing? Are you adding a decent amount of acid? Mine keeps creeping up but I'm told this is normal as the surface continues to cure. I'm almost to the point where I need to add baking soda to bump up the TA (in the 70-80 range right now).
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    I would add 3000ppm, or whatever the low number in the recommended range in your SWG manual, of salt on day one and brush, leave the pump running, on low if you have a low.
    Have you seen this handy page?
    Pool School - Water Balance for SWGs
