Results 1 to 15 of 15
Thread: What's Up with My Speed Stir?
    Jul 2015
    Clearwater, FL
    83
    Got the speed stir about two weeks ago. It worked beautifully at first--the magnetic capsule spinning well, Lately, though, the capsule stirs a little than just wiggles back and forth, Anyone have experience with this?
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: What's Up with My Speed Stir?
    mine does that some times. depends on which vial I use from the TF-100 test kit.
    just give it a bump and it should spin.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    griffin, ga
    29
    Might seem too simple, but have you tried a new battery? The unit is just a small motor with a magnet that spins, that pill is also a magnet that is just chasing the one on the motor. So, if the motor is not turning it will just wiggle like you are talking about, until the battery gets low enough that it doesn't move at all. If a known good battery doesn't work, then it might be that the internal magnet is no longer attached to the motor.
    24ft Round AGP, built 5/10/15, 13500gal, 1hp Hayward pump, sand filter, hard piped, Pulsar Pulsatron Auto clorine pump. Intex auto cleaner robot. TF-100 XL with speed stir.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Yep, new battery or take the cover off and spin the old batteries in the compartment.
    Sometimes just a tiny bit of corrosion grows in the contact area and rolling the battery rubs/sands it off to expose fresh metal.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2015
    Clearwater, FL
    83
    I thought about batteries, but the thing is only two weeks old. Will check them anyhow. Thanks.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    I had the same problem, to the point I was calling it The Spaz Stir. A new set of batteries brought it back to new operation.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Jun 2015
    Freehold, NJ
    20
    My original batteries lasted for one use. The batteries that came with the unit were well past expiration. A new set of batteries fixed the problem of the vibrating pill.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Same here, mine did the same thing when I first bought it, new batteries fixed the problem. I find a good set of batteries will last for 6 months or so of routine testing.
    Jul 2015
    Clearwater, FL
    83
    New batteries did the trick. Thanks all.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    What size batteries does it take?
    30,419
    It takes double A's but I don't want any of you to eat dead batteries if you got your stirrer from TFTestkits.
    We really take pride in shipping you everything in tip top shape and we need to know if you have any issues---including dead batteries.
    We are a little Mom and Pop place but we can act responsibly and make sure you get what you pay for.
    I would like to hear from you via PM (otpirate) if you got batteries from us that failed prematurely.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Not a problem here. The ones I replaced were the originals and they were on their 3rd season.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    That's really cool Dave! The world could use more of that!
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    30,419
    Thanks, ZF,
    "Do unto others...." is not exclusively Christian....It's a great guideline for conducting business, too.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Thanks, ZF,
    Well done Dave .... as you always do!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
