Results 1 to 8 of 8
Thread: Still seeing sand/algae on bottom of pool after SLAM
    Jul 2015
    Eaton Rapids
    41
    Ok, so I've been slamming my pool for the past week. The last couple of nights I've passed the overnight FC test and my pool is keeping a good FC level (around 12 for the SLAM). My CYA is holding steady at 30 and my PH is around 7.6. Everything seems to be good.
    I've been vacuuming up what I thought was algae everyday. Sometimes on filter sometimes on waste. Every morning when I wake up and check the pool though, there is junk on the bottom.
    My initial thinking was that it was algae, but now I'm starting to think it's sand. It seems to happen more when I run the filter for and extended period time. I've been back washing and rinsing my filter every other day but the stuff on the bottom just keeps coming back.
    Any ideas??
    7600 gallons AG. Hayward Sand filter. Taylor k-2006.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Still seeing sand/algae on bottom of pool after SLAM
    Collect some and lets see what it is...
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Eaton Rapids
    41
    Quote Originally Posted by pabeader View Post
    What's the best way to do that?
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Quote Originally Posted by Newerabs View Post
    What are you using to vacuum with?
    You could just use the vacuum hose without anything attached to it.
    Just put a nylon sock or panty hose over the end and suck up some of the debris.
    It will allow water to flow by and trap some of the debris for closer inspection.
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Turkey baster works best.
    Jul 2015
    Eaton Rapids
    41
    Once I do that, what should I with it? Just look at it closely to see if it's sand?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Spritz it slowly onto some paper towel. Take a picture. I'm sure some folks here will want you to touch it and smell it and all kinds of other stuff.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Yea touch it you might be able to tell
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
