Results 1 to 13 of 13
Thread: Problem with my chlorine kit?
    Jul 2015
    Pittsburgh
    38
    Hi all! My fas/dpd kit has worked great since I got it a few weeks ago. All of a sudden yesterday, when I put the powder in, it didn't register at all. My brain almost broke, lol. I added a few drops of bleach to a new water sample, then added powder again. The powder itself initially turned pink, but the water didn't and then all went clear again. I can't remember what I did next, but the next sample worked like it always has. Now today it registered zero again. Any clue what's happening? The only thing I've done differently to the pool itself is add some calcium two days ago to get the level up.
    50 yr old in-ground plaster pool
    15'x40' 3ft to 9ft
    22000 gallons - we think
    1hp jacuzzi pump and sherlock cartridge filter
    Taylor K-2005 test kit
    22,549
    Re: Problem with my chlorine kit?
    Try using the OTO kit and see if it changes color. If it does then you may have enough FC to bleach out the DPD test.
    Jul 2015
    Pittsburgh
    38
    Is OTO the one that comes in the K-2005 kit where I just compare color?
    15'x40' 3ft to 9ft
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Quote Originally Posted by LexieLou View Post
    Yes.
    Jun 2011
    Long Beach, CA
    2,786
    I believe the K-2005 has the DPD test not the OTO and the DPD test will also bleach out if there is too much chlorine. Try adding more powder to see if that helps.
    Jul 2015
    Pittsburgh
    38
    Quote Originally Posted by ping View Post
    I'll give it a try, but I can't imagine that's it... it was at 2.5 yesterday, and I only added half a gallon of clorox last night. I'll report back!
    15'x40' 3ft to 9ft
    Jul 2015
    Pittsburgh
    38
    So... I realized that with the somewhat small leak we have, and having to top off the pool every three days or so, my CYA level is really low, having dropped over the last 2 weeks. Like, lower than I can measure. We've had some sunny days lately. So I added a gallon of clorox and checked back after 30 mins. Chlorine test showed FC: 1. I just put about a pound of stabilizer in the skimmer and another gallon of bleach in the water. So glad for all I've learned here! I'll keep on top of the stabilizer and be more vigilant about the bleach. Thanks, guys!
    15'x40' 3ft to 9ft
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    When I added Calcium a week or two back, my FC took a major (unexpected) hit.
    That may have had some influence on your early tests, that your FC was really 0, so nothing to turn it pink.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2015
    Pittsburgh
    38
    Quote Originally Posted by ozdiver View Post
    Interesting! That would make sense here, too. I wonder why... I added more calcium last night along with a load of bleach..I'd better go up and check the FC.
    15'x40' 3ft to 9ft
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Adding calcium is not going to drop your FC level. Something else, either Sunlight or organics is consuming your Chlorine.
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    What I love is that you KNEW just what to do! Problem-----ask at TFP=solution!
    You have learned a lot!
    Kim
    22,549
    The only way adding calcium could possibly affect the fc is if it wasn't pure and had organics in it that consumed the chlorine. It would take some pretty dirty stuff to affect it very much.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    FC had been stable; testing daily, reading 5 and being dosed up to 7 with bleach (Pucks were running in background to raise CYA a little).
    Day after adding a fresh sealed bucket of CaCl from Leslies, tested FC @ 1.
    Unless every squirrel and raccoon in my neighborhood decided that night was the night to party in my pool, I have no other explanation.
