Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Bleach
    Jul 2015
    Windham, NH
    49
    Bleach
    I'm in the process of slamming my pool and having trouble with the correct bleach to use. Purchased Great Value brand at Walmart and other than scented/ concentrated they had what is labeled at Cleaning Bleach. I used the amount suggested by pool math and doubled the FC that it should have brought me to for shock level. Running out to buy more bleach but want to make sure I'm using the right stuff.
    13,541k g, AG, SHarkline Heritage 24', Hydromax AC DE95 Filter, Vinyl
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Bleach
    Is there a % hypochlorite listed on the bottle?
    Isolated Spa - 345 Gallons
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Bleach
    Cleaning bleach has been reported as only 3 or 4%. you need to adjust the % in pool math.
    Quote Originally Posted by Dbustamante00 View Post
    Weird. Must have been out of the regular, concentrated bleach. BTW concentrated is fine, just make sure there is no additives like scents and stuff.
    Wonder if the gallons of pool volume is off?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Windham, NH
    49
    Re: Bleach
    It says 6% sodium hypochlorite on the bottle. So I can use concentrated? My pool is only full about an inch past the skimmer. How full should it be? Silly question I guess.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Bleach
    The concentrated is just the higher percentage. 8.25%.
    Clorox decided at some point to make the bottles smaller (121oz instead of 128oz) and change the concentration to 8.25% from 6%.
    They probably raised the price too for the new "concentrated" stuff!
    Most of the store brands followed along. Marketing. Gotta love it.
    Great value just recently brought back the 128oz 6% and called it "cleaning bleach".
    The 8.25% is usually the better value though. (as long as it's not splashless or scented)
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2015
    Windham, NH
    49
    Re: Bleach
    Ok great! Thanks.
    Jul 2015
    Windham, NH
    49
    Re: Bleach
    Should I be pouring the bleach into the skimmer or directly into the pool?
    30,419
    Re: Bleach
    Directly into the pool but fairly slow in front of a return stream so it mixes quickly.
    38,284
    Re: Bleach
    This explains how to add chemicals: Recommended Pool Chemicals
    Jul 2015
    Windham, NH
    49
    Re: Bleach
    The pool is now cloudy and almost clear. No more green. Now there are what seems like bands of cloudy yellow lingering in the pool. Any idea what this could be?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Bleach
    Sounds like dead or dying algae. Are you brushing daily? Scrubbed under ladders? Lights? Keep SLAMing.
    Jul 2015
    Windham, NH
    49
    Re: Bleach
    FC level dropped from 15 to 12 over night and CC level remains at 1. Still SLAMing but have to leave the pool for the day. Any suggestions on what I can do before leaving so I'm not undoing all that I've done the past several days? Feels like the pool is never going to get to where it needs to be. My CYA level is at 39. Once I add more bleach to increase FC to 15 to maintain shock level it's just going to fall while gone all day. Pool is in full sun during mid day.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Bleach
    You can always put extra in. It will get used by the sun quicker but that's better than it dropping too far while you're gone.
    You can always put extra in. It will get used by the sun quicker but that's better than it dropping too far while you're gone. According to extended chart, you are safe up to 23ppm for short periods of time.
    http://www.troublefreepool.com/threa...rine-CYA-Chart
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Bleach
    If you have an Ocean State Job lots near you they have 12.5% full Gallons for $2.99, sometimes less.- It's sold as 'liquid shock'
    Find Us - Ocean State Job Lot
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Aug 2015
    San Antonio
    74
    Re: Bleach
    I was going to start a thread on this and have been researching bleaches on the forum. That turned a 15 minute trip to Wal Mart into an hour plus as I was pulling MSDS sheets on different brands.
    Many bleaches had a range and stated that due to trade secrets the exact percentage can not be given.
    My conclusion - if I am going to pay ~$2 per bottle for something that has a range of 1-4 or even 1-6 % chlorine I might as well go to the dreaded pool store and get the $4/128oz 12.5% mixture. Plus I will have a more accurate time using pool math.
    Matt in San Antonio
    10,000 gallon IG plaster
    Pentair Intelliflow 2VS 3hp 3/4 hp booster pump
    Hayward C-1100 Cartridge Filter
    Sunluway 18w Color changing led light
    38,284
    Re: Bleach
    Walmart bleach turns over so fast that it is at least the 6 or 8.25% ... sometimes higher if it is fresh.
    Aug 2015
    San Antonio
    74
    Re: Bleach
    Is that the Great Value brand or Wal mart brand?
    Both are WM branding neither had % on bottle. Where are you getting your numbers?
    Matt in San Antonio
    38,284
    Re: Bleach
    Great Value ... and I have never not seen the % listed on the bottle.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Bleach
    Left is target store brand "up & up". Right is walmart store brand "great value" (concentrated not "cleaning bleach" label)
    This is how they are labeled in Virginia Beach and all of Hampton Roads Virginia area.
  20. Back To Top    #20
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Bleach
    I use Target Up & Up, Walmart Great Value, and Chlorox. All of them are labeled with the percent. But I have noticed that "easy pour", splashless, scented, etc. are not labeled with the percentage, but of course no one should be using these in their pool.
    In general, I'd say if it's not labeled, then don't buy it.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
