Thread: Skimmer
    Aug 2015
    Katy Texas
    5
    Skimmer
    My skimmer does not seem to be working very good, I am using a net to clear surface debris. I notice the opening is large around 3-4 inches of water entering the skimmer. Shouldn't there be a weir or something to reduce the area of skimming to around 1/2 inch? I think the opening is too large for the skimmer to work. Am I correct or is there something else I can check. If I am correct can I lodge a piece of 2x4 in to narrow the skimming?
    Turtleman
    22,544
    Re: Skimmer
    Welcome to TFP.
    First tell us more about your pool? Is it In ground, Above ground?
    Placing a 2x4 in the skimmer won't solve the problem and may create a worse problem. The weir doors in a pool are hinged on the bottom and have a float in them so they stay just under the surface. Whatever you place in there will need to do the same thing.
    Aug 2015
    Katy Texas
    5
    Re: Skimmer
    In-ground 30K gal, do they sell hinged weirs I can install?
    Turtleman
    22,544
    Re: Skimmer
    They sell replacement as well as universal weirs. Your best bet is to look in the skimmer throat and find out which type and size you need and get one as close to original as possible.
    Keep in mind that some older pools didn't have weirs. You can still install a universal unit in those.
    Aug 2015
    Katy Texas
    5
    Re: Skimmer
    I checked and this pool never had a weir. I will shop around and try to find something that can be installed, thanks for the tip.
    Turtleman
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Skimmer
    Sunplay has all shapes and sizes.
    Pool Skimmer Weirs. Skimmer Weir Doors. Skimmer Weir.
