Results 1 to 9 of 9
Thread: Chlorine
    Aug 2015
    Katy Texas
    5
    Just moved in to a 1973 house with a pool. What is the best chlorine to use? I have been using Clorox concentrate(1 gallon to 30k H2O) with positive results but it only last a day or so. I get to 4 ppm today but tomorrow it will be 1 ppm again. Is it necessary to add clorox everyday? Should I use some other chlorine? I am also adding acid (3 pints to 30k H2O) to bring Ph down about once a week. The pool was resurfaced/repaired last winter.
    Turtleman
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Chlorine
    Chlorine is all the same, at least when it comes to bleach. It's all sodium hypochlorite. Buy the best deal you can find and check the expiration/manufacture dates on the bottles. Old bleach is weak bleach as it loses strength over time. I buy 12.5% pool shock (bleach) because it's the best deal and I have to carry around less bottles and dispose of them. Just make sure it's not scented or outdoor or splashless bleach. To figure out the best deal, take the price, divided by the number of ounces then multiply by the percentage. Example of my sweet deal: $2 for 128 ounces of 12.5% bleach. $2.00/128*12.5 = $0.195 per ounce hypochlorite. Lower is obviously better.
    Isolated Spa - 345 Gallons
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Chlorine
    We could really use a complete list of your pool and equipment. Also what test kit are you using? You need to know your CYA level to know where your FC should be and how it's going to act in the sun.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Chlorine
    Welcome to TFP! Congrats on the new pool!
    Here are a couple of articles from Pool School to get you started.
    Pool School - Getting Started
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Re: Chlorine
    Welcome to TFP congrats on your new pool. You will definitely find lots of help here
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Aug 2014
    Shallotte, NC
    693
    Re: Chlorine
    Quote Originally Posted by Terrellhome View Post
    Whatever is cheapest (considering both cost and strength).
    Clorox is fine, but kinda pricey. The store brands work as well and cost less per unit of chlorine. The short answer? Expect to put chlorine in every day, maybe twice.
    You don't need to.
    OK, not enough information.
    You need a good test kit, like the Taylor K-2006C, if you don't have one. Then we need to look at your water chemistry as a whole, before we can advise on pH, TA, and CH.
    Aug 2015
    Katy Texas
    5
    Re: Chlorine
    All the other test results are at or close to ideal. I had an above ground salt water pool before moving here and am not use to dealing with chlorine. Sounds like adding chlorine daily or every other day is what I need to be doing. Thanks for the tips on buying and adding chems.
    Turtleman
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,207
    Re: Chlorine
    Daily testing and additions are best. With automation like your SWG or my Stenner pump you can stretch out the testing intervals because you know it's getting its daily diet of chlorine.
    Just be sure to use a quality/accurate test kit, not strips and stay away from most pool store testing.
    Support the site
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Chlorine
    I'm sorry but telling us chemicals are ideal does not give us enough information to help you. The TFP version of "ideal" is different from the standard pool industry notion of "ideal". If you could post the test results we could let you know if the chemistry is good or if there are levels that need adjusting.
    I don't know if you are new to the Houston metro area or not, but this summer has been unusually hot and dry since mid-June and folks around here are adding more chlorine more often this year.
    Love TFP? Become a
    TFP Supporter!
