Thread: Question about borax - have a vinyl liner pool under a massive amount of trees
    Jul 2015
    franklin/tn
    96
    Pool is about 1/2 in the shade by 3 pm and full sun by about 10am in the morning.
    Would i be a caondidate to use borates to keep my pool sparkling? I am just completing my first SLAM and I cannot believe how good the pool looks already.
    Absolutely blown away.
    I never want it to turn green again, but am concerned with the amount of debris (particularly as Aug/Sept approaches) falling into the pool.
    Is there a rule of thumb as to whether its worth taking this additional step based on the type of pool?
    33x15' INGROUND pool roughly 14,800 gallons. liner, hayward multiport, sand filter (S-210S), pentair century 3/4hp pump (1081) & 320 automatic chlorinator. skimmer at one end of pool, 2 returns at the other.
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: Question about borax - have a vinyl liner pool under a massive amount of trees
    That's a great question. I too am under trees, and constantly remove debris (my 5YO calls it 'tree-bris").
    My pool remains clear, but I'm curious if there is anything special I should do. I'm already pulling leaves out of the skimmer!
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's a personal choice and entirely optional either way. As debris entry goes, there is no advantage or disadvantage to Borates. It would behoove you to post a full set of numbers before you add them however. And I'll add, that I am not against them at all, but I do suggest getting a tight grip on your knowledge, testing, and caring for your pool before adding more to the equation.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Have you read this? Borates - Why and How
    I am a big fan of borates. It makes the water feel nice, cuts down on bugs which means a lot because we are in the woods, I get some PH relief, but I still have to add acid at least weekly depending on how much the wife wants the waterfall running. Mine was down to 20 this spring due to all the rain. Water was less sparkly and more bugs. Bumped it back to 50 and it was almost instantly better.
    You should have your PH and TA understood and under control first. Tell us where you are and how it has been recently.
    I also have dozens of trees and they are dropping leaves like crazy because it is so dry. I went fro spring pollen and stuff to leaves falling. My skimmer baskets are full twice a day. Pump never left the 24x7 spring run cycle to keep leaves in the skimmers and off the bottom.
