Thread: I'm so new at this I've never done a Forum before.
    Aug 2015
    Hastings, NE
    1
    We have an above ground 18' round pool. Had it for about 5 years. This is the first year that we've come across this problem. We use chlorine to and do not have a sand pump filter. Keep our filters changed regularly. Check our chemicals daily. For some reason, this year our pH is sky high and we've developed a gritty substance along the edge of the pool. It's almost like a salt grit put larger than salt in a shaker. Our water is clear, not cloudy. We can't seem to get the pH down. Any ideas?
    BTW, we live in South Central Nebraska. The humidity has been horrible. We keep the pool covered when not in use or the bugs and weed seed would be horrible as we have pasture land behind us (practically in our backyard) and soybean field across the road from us.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: I'm so new at this I've never done a Forum before.
    Welcome Melodie
    Sorry to begin with a question. What is it you're doing to lower pH that isn't working? It does sound like you are creating scale at the waterline, which would not be surprising with high pH and concentrated minerals. Can you tell us what kit you have, and tell us about other test results you may have?
    Essential Links:
    Jun 2014
    15,153
    Welcome to TFP! Here's a couple basic links that may help you out in the future:
    Have a nice weekend!
