Results 1 to 7 of 7
Thread: Intex Skimmer Mod
    hippyengineer's Avatar
    May 2013
    Houston, TX
    7
    Intex Skimmer Mod
    I've had this modification on my pool all summer and I love it. It makes it really easy to install and remove the skimmer. I waited to post since I wanted to be sure it didn't put any stress on the pool wall.
    I have a Hayward wall fitting that accepts the 1-1/4 threaded male to 1-1/2 female PVC adapter. I used 1-1/2 pipe and fittings and 1-1/4 to 1-1/2 adapter to the skimmer. I didn't glue the t fitting so I could adjust it and left it loose at the wall for removal.
    Intex 15' X 52" Easy Set (modified for larger inlet/outlet)
    Intex 1600 GPH Sand Filter
    Intex SWG
    Happiness!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intex Skimmer Mod
    That is a great idea. I am sure it will help many who do not want to cut their liner to install a skimmer.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2015
    Central FL
    2
    OMG you solved it! The intex skimmer is not what it used to be
    8,400 gallons above ground
    well water.......very hard
    Intex 12x24
    Sand Filter
    Central FL
    May 2013
    Houston, TX
    7
    Thanks Julie! I hope it helps.
    Intex SWG
    Happiness!!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Congratulations, what is the reason to use a T instead of an elbow?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    May 2013
    Houston, TX
    7
    At the end of the T I put a cap that I could remove if I wanted to connect something else to the line.
    Intex SWG
    Happiness!!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by hippyengineer View Post
    Good idea, thank you
