Results 1 to 20 of 20
Thread: Prevent splashing from Clorox liquid
    May 2013
    Dallas, TX
    69
    Red face Prevent splashing from Clorox liquid
    I have a great collection of almost new tee shirts with white spots all over them from splashes during the pouring of Clorox into my pool. I found a solution. From an auto supply store (or Amazon) buy a spill-saver transmission fluid/oil spigot that screws (tightly) onto the mouth of the Clorox jug. They cost a few dollars but can save you ruined clothing. You can then just lay the jug on its side with the spigot in your drain and let the Clorox slowly drain out of the jug while you stand at a distance. There are no splashes because of slow drainage.
    Just be sure to be careful when unscrewing the spigot before you rinse it in the pool! I do this with the jug and spigot in the pool to prevent rogue drips.
    This has solved my bleach splashing problem.
    In-ground plaster pool, ~18,500 gal, Hayward single-speed pump, Pentair 60 sq. ft. DE filter, Polaris 280 robotic cleaner, SPA, heater (seldom used), use Taylor K2006 series test kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Prevent splashing from Clorox liquid
    Thanks
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Aug 2014
    Shallotte, NC
    693
    If I understand correctly, pouring bleach into piping headed back to your pump is not recommended....
    May 2013
    Dallas, TX
    69
    I thought I had read on this forum a few years back this was the preferred method to introduce chlorine into the pool. If not, then the directions above should be modified to placing the spigot over the side of the pool in the deep end near a pump outlet.
    See this discussion: pour bleach in skimmer or directly in pool?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Since 2009 we have had reports from a pump rebuilder that he gets most of his business from folks who put chems in their skimmer. Granted, it's still anecdotal but why take the risk? I think I've also read of a few folks skimmer baskets getting brittle. That might not be from the chems, might be just age. YMMV.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2014
    Shallotte, NC
    693
    This is my opinion, backed up by conclusions drawn, by others, in this forum.... so, here's my take. Before retirement, I ran a machine shop and did a LOT of electric motor repair. There were some pool pump motors that I got to see a lot... over and over.... due to corrosion. I wasn't a pool owner, then, and knew little about pool chemistry. Putting two and two together, the consensus was that the pumps were probably eating a steady diet of chlorine.... from pucks and/or chlorine going into the skimmer. I have no smoking gun....
    I am, however, developing another take and a possible contributing factor... and that is one of electrolysis, bonding, and ground loops....
    Wish we had a CSI for pumps....
    May 2013
    Dallas, TX
    69
    Into the skimmer, into the pool, whatever ... if you want to avoid wiping out your clothes with a splash when pouring from the Clorox jug ... and I have not found the trick to pouring the stuff directly out of the jug without getting an occasional air bubble that interrupts a steady flow and gives me a nice splash of pure Clorox in all directions ... try one of the transmission fluid pouring spouts. Works like a charm and it slows the flow. You can just leave the Clorox jug on its side and let it trickle into the pool and come back later.
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Do NOT pour bleach into the skimmer! Pour it in front of the return.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    May 2013
    Dallas, TX
    69
    Quote Originally Posted by Skitch View Post
    Wow, I posted something about splashing Clorox and I got a discussion about where to put it into the pool.
    So, where is the “return?” Are you referring to the opening to the skimmer from the pool? I have return lines from two skimmers and the main drain. Please clarify.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    A return, returns the water to the pool.
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    No offense intended, but there's a lot of newbies that lurk and I wouldn't want them adding bleach to the skimmer, directly into the pump.
    I pour my bleach into a plastic measuring cup and slowly add it to the pool in front of the jet that returns the water from the filter back into the pool
    No problem with splashing, it mixes as I add, and my pumps life is extended.
    May 2013
    Dallas, TX
    69
    Quote Originally Posted by pabeader View Post
    Oh, OK. I was thinking of returning water to the pump.
    Mar 2007
    San Rafael, CA USA
    12,082
    Pouring acid in the skimmer is far, far worse than anything else. Trichlor pucks without continual water flow are also a problem because they are also acidic (though not nearly as acidic as Muriatic Acid) and they are also high in chlorine. Pouring bleach or chlorinating liquid into the skimmer is less of an issue because it is higher in pH and therefore the active chlorine (hypochlorous acid) level is lower.
    For chlorinating liquid or bleach in pool water, the maximum active chlorine level reaches 5 to 11 ppm FC (so equivalent to 10 to 22 ppm FC with no CYA at pH 7.5) depending on concentration and dilution. As the concentrated product is diluted, the pH drops and the active chlorine level rises until that peaks and then the dilution of the chlorine itself outweighs the pH effect. Also, the concentrated hypochlorite itself has some oxidizing capability. The chlorine is certainly not as innocuous as adding, say, baking soda, boric acid, or calcium chloride. As to whether this temporary high active chlorine level is a problem is open to debate.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    I'm a lefty and a bit clumsy and I solved my spotted clothing problems by keeping a full length white terry robe hanging by the pool It's working out really well because its also great to wrap up in after a morning swim!
    I am at times enough of a klutz that I would probably spot myself trying to get the transmission nozzle in the botte
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I don’t know if it’s the design of its vented gallon jug, but ever since I found a source for low priced 12.5% Liquid Chlorine, I seem to have great success pouring without any splashing like I had with ‘Bleach’ jug’s.
    Of course now that I’ve made this statement I’ll most likely wipe out some cloths when I do my daily add today
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    30,403
    OP makes a very good point. The Admin and Moderators here encourage everyone to keep threads and subsequent posts "on topic".......it makes the threads quite a bit easier to follow.
    It is difficult not to drift off sometimes and certainly all these posts are courteous and pertinent but it is nice to see this thread lead back to it's original idea.
    BTW, I lower the Clorox jug into the water and then tip it over holding the mouth of the Clorox just an inch or two above the surface......no drips.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    That seems to work the best for me, too. So far, knock on wood, no bleach stains this year.
    Aug 2011
    Central Valley California
    121
    Nice to know. I sure have a lot of spotted shirts and shorts also.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I lost a few new shirts last year. Made sure tons hanged into grungy clothes when pool forst got filled. Now I seem to have it better, crossing fingers I don't jinx myself for saying that, ha.
  20. Back To Top    #20
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I pour everything into a 5-gallon orange bucket from Homers that is half to three-quarters full of pool water and then walk around the pool slowly dumping it in reaching as far into the pool as possible...as far from the edge as possible. The diving board allows me good access to the deepest end far from the edge.
    I do this with muriatic acid, baking soda, calcium chloride, etc. My Liquidator injects the sodium hypochlorate.
    I don't seem to have issues with splashing anything...so far.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
