Thread: Help with Pebble Tec Salt Water in groung pool
    Aug 2015
    Chicago,illinois
    1
    I have a home in Arizona and have a pool maintenance person out weekly. I haven't had much time this year to get to Arizona and am having some issues in my pool. I had a Hayward pool cleaner and it seemed to not be working well and took it off. I have a salt water in ground pool about 6 ft deep. I have a newer (3 yrs old) 3 stage pump. I am looking for a pool cleaner that might not need me to over-see it daily (since I am not there). My pool cleaner recommended barracuda, but I haven't seen great reviews on that system. Help!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help with Pebble Tec Salt Water in groung pool
    Welcome to TFP!
    A suction cleaner is likely best in your situation, but I'm sorry I don't know which ones are best to recommend. Others will weigh in with experience I'm sure. If you would please, change your location to AZ since this is where your pool is located. While you are at it, the info about your pool placed in your signature will help us answer questions much better and faster for you.
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,788
    Please post more details about the pool. How many skimmers, is there a dedicated suction line, pump size, pool size, any automation, etc. will help us to better answer your question.
