Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Reading CYA test
    Jul 2012
    Central Texas
    436
    Reading CYA test
    A little while back, as part of another thread, I seem to temper a sidebar discussion about reading the CYA test, comparison to the known sample, etc. I don't remember what the root thread was so I can't find it to find out what the outcome was.
    My wife and I read the CYA results differently. Her eyes are better than mine. I 'see' (pun intended) it disappear at a higher value than she does (i.e. at a lower fill level on the column). But it is the most variable of the tests, at least to my thought process. I've always been 'concerned' about overshooting CYA and having to partial drain to resolve. We are typically about 10ppm different. I also have variability just reading the test in different days in the 'same' conditions.
    Does anybody remember what happened in that thread? Or a reference to it?
    My only concern is I read it as 70 and she reads it as say...40. That would be a huge FC difference and easy to go under the target in Texas August sun loads.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Reading CYA test
    I was reading it at a higher level, until I realized that what I was seeing as the dot still showing was in fact the outline of the sticker the dot is printed on. Easy mistake if your eyes aren't good and you are straining to look for that dot.
    chiefwej
    Jul 2012
    Central Texas
    436
    If you were still seeing the sticker, wouldn't that mean you were reading it at a lower level?
    So have you moved to looking at the interior of the circle to define your read level?
    My problem (one if them anyways... ) is the tube is so narrow that my eyes lose the focus as it starts to fill and becomes murky and you're looking at it from a distance (eye to bottom of tube)
    Jun 2014
    15,008
    It IS the trickiest of the tests to perform. I always try to remember that proper lighting is important for the CYA test. You want to test for CYA outside on a sunny day, but keep the skinny view tube in the shade. Taylor recommends standing in the sun with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
    When all else fails ... remember the wife is always right. Well, okay, maybe not always, but always best to be cautious.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by eqbob View Post
    You could always pick up a bottle of the 50ppm standard and see who's correct.
    http://tftestkits.net/R-7065-CYA-Sta...ution-p34.html
    Loser makes dinner LOL
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,403
    That's just not real life experience. Consistently, folks can get within 10-15 ppm on a test. If you ever get a variance of 30 ppm, I would visit the optometrist.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    My suggestion on the other thread you were asking about, was to get the 50% solution and then figure out where in your house, yard, garage, you have to be to get it to register 50%. Then use that same place to read your pool water. What you are doing is calibrating your testing to a known setting. As long as you use the same testing environment you can expect reasonably valid results.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hi eqbob, Dave is probably thinking, Geez it's like lefty all over again . Pabeader is right, I got the reference solution and still didn't get a 50 reading until I wandered around the property and found a sweet spot, and now I try to test there same time of day and same sun conditions.
    I think you will get comfortable with the reading and feel confident your right (or probably the wifes). If the boss is happy were all happy
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Jul 2012
    Central Texas
    436
    Quote Originally Posted by Texas Splash View Post
    That's largely what I do, but there are some nuances there I will try to implement and see if that improves my consistency.
    As far as the wife, the saying of "I may be a lefty, but I'm always right" is a favorite of hers <LOL>
    Quote Originally Posted by lefty51 View Post
    Yep...if momma ain't happy....ain't nobody happy <G>
    LOL. I hear ya. That scenario was as a potential, could it happen type of deal, not a recall of an actual situation. I do have a right eye vision problem that took away clarity at a close situation and it can't be corrected, but it hasn't been a problem yet in reading any test results. As you said, we are generally within 10.
    Quote Originally Posted by pabeader View Post
    I like that. Thanks!
    lefty51's Avatar
    May 2015
    451
    I'll just add, if she's a lefty, I KNOW she's right
    frbruno64's Avatar
    Jun 2015
    Berwyn, PA (Philadelphia suburb)
    20
    I automatically close my left eye and use my right eye to view the dot from above, (similar to looking in a microscope or telescope.)
    Does this test require both eyes to be open?
    33k, IG Pebble, 1.5hp Challenger, Pentair FNS, TF-100
    Jul 2012
    Central Texas
    436
    We did a comparison test today and we're within 5. She read 45 I read 50.
    Jun 2014
    15,008
    Hey! That's much closer. You are starting to read the CYA like a team. When you get that close, probably best to go with the higher number. Just like taxes - round-up over 5.
    Jul 2012
    Central Texas
    436
    Yep. Today will up it to the proper level.
    Jul 2012
    Central Texas
    436
    80 ounces in the water. Should now be at 70 next time I test.
    Aug 2015
    San Antonio
    74
    Is there a time limit as far as the read goes. I have noticed that I "see" the dot disappear and then it seems like it reappears. I don't know if it's just my eyes adjusting or the solution settling.
    Matt in San Antonio
    10,000 gallon IG plaster
    Pentair Intelliflow 2VS 3hp 3/4 hp booster pump
    Hayward C-1100 Cartridge Filter
    Sunluway 18w Color changing led light
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I always test CYA when the dear wife is at home. We pour back and forth, each come up with a number and average. To be honest we are usually within 5 - 10.
    Support the site
    Jul 2012
    Central Texas
    436
    Quote Originally Posted by Hereinthe210 View Post
    I believe there's a very different answer for that question depending on whether you're using liquid or solid stabilizer. The solid takes much longer to move into the water and appear. I think I recall seeing statements of up to a week past everything being dissolved? I'm not entirely sure as I've never used the solid.
    The liquid says it is "instant". In practice, I wait 8-24 hours after putting it in before redoing a measure of CYA.
    Aug 2015
    San Antonio
    74
    Reading CYA test
    I just did a 80% drain refill. I used the multiple eyes (mine and daughter's) and we both came up with 45 while standing in direct sun with our backs to it holding test kit waste level. Now I am confident that the drain helped out and glad that my new TFP friends recommended the drain.
    Matt in San Antonio
  20. Back To Top    #20
    Jun 2015
    Pasco, WA
    206
    I have a question on the results. My husband and I come up with different readings sometimes also. But he holds the tube with his hand almost completely covering the sides of the tube. I hold it at the top with light getting through most of the tube. I did it his way to see what I got. It really does make a difference if the tube is mostly covered or mostly not covered with the light going through the tube. Which way is the correct way to hold and read?
    19,000 gallons, In ground 16 x 32, Vinyl liner, Sand filter Hayward Pro Series S-244T (300 lb media), Pump Hayward 1 hp, Install March 1998, water test kit- TF-100 -- New Liner installed 07-07-2016 -- Mountain Top/Blue Mosaic by Kafko, Installed new 1 hp pump motor on 06-28-2017
