Results 1 to 7 of 7
Thread: Backwash - how often?
    Jul 2015
    Scituate, RI
    30
    How often do you guys backwash? Do you do this on a steady schedule, or base it on the pump pressure. My pump has been in the "green" zone for about 1.5 weeks. It has risen 1 psi, but this is due to my adding of 2.5 cups of DT.
    Bob
    Intex Ultra Frame 16 x 48 (5000 gal) - Fresh Fill on 7/13/15
    Intex Model ECO 20110 Sand Filter/SWG (2150 gph)
    Intex Deluxe Surface Skimmer
    TF-100 Test Kit, Taylor K-1766 Cloride Drop Test, LaMotte Borate Test Strips, Speed Stir
    Aug 2014
    Northern IL
    4,615
    Re: Backwash - how often?
    The recommendation is to backwash only when psi goes up around 25% over clean.
    Next time you do backwash, check the psi. Don't trust the "green". You can always use a sharpie to tic the clean psi on your gauge, calculate 25% higher and then tic that.
    Also, check your gauge once in a while to make sure it goes to zero when you shut it off.
    Jul 2015
    Scituate, RI
    30
    Thanks. It's clean/nominal, pre-DT add, is about 7.5 psi. My DT addition brings it up to 8.5 psi. It's running at about 9.5 psi (my 25% mark would be about 10.63 psi, but the gauge is not nearly that precise (and probably not that accurate as well)). I may have to look around for a better gauge.
    38,260
    I see you have the TF-100, they also sell really nice gauges there.
    Aug 2014
    Northern IL
    4,615
    I am pretty sure your 25% should be based off of 7.5, not the post DE of 8.5. My clean pressure is way higher so I have more wiggle room between clean and "dirty".
    TFtestkits sells gauges!
    Hahaha. Great minds...! Cross-post
    Jan 2012
    'burbs of Augusta, Georgia
    7,285
    I only backwash once *maybe* twice a summer? I just don't get much to require it. Gauge works fine.
    I have read here that over-doing the back washing can actually make the filter medium less effectiv3 (a slightly dirty filter works better than a pristine clean one).
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Skimmer socks and my dolphin.very few back washing a for this pool owner!
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
