Thread: Left my test kit in the sun...
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    Hello,
    I accidentally left my TF-100 kit on the back of my tailgate for a couple hours on hot day (100 degrees). My r-0871 leaked all over the bottom of my kit and the next time tested my chlorine it was off the charts. I am assuming I need to replace it? So do I need to replace just that one or everything? Thanks.
    Sara- 29,000 gal IG Plaster '93
    DE system:3 (S8D110) 58 sq ft
    Pentair Superflo 3/4 hp single speed
    Booster Pump 3/4 hp-Polaris 280 vac-sweep
    8 return jets- 2 skimmers- TF-100
    Aug 2014
    Shallotte, NC
    693
    Re: Left my test kit in the sun...
    You'll definitely need to replace the R-0871... it isn't just by chance that Taylor packages that reagent in a brown bottle. You might consult this link for advice:
    https://www.taylortechnologies.com/ChemistryTopicsCM.ASP?ContentID=2
    mrswilson's Avatar
    Mar 2015
    Redding, CA
    41
    Ok thanks. I'll check out the link.
