Thread: How can I tell of DE is coming through the returns?
    Aug 2015
    Boston, MA
    32
    Hello all,
    So I added DE the other day and things were running fine. I tried connecting my vac by shutting off the main drain and shallow end valve while leaving the deep end open. Turned on the filter and when i stuck the end of the vac to the deep end all of a sudden the filter clicked and stopped and psi went down to nothing. I opened back up all valves turned the filter on again then from the deep end return I saw some white streak like coming from the return but now has stopped and not seeing anything. When the filter first turned on I saw bubbles from each return then they started running. How do I know if the DE is coming out of the return? The loud click and shutoff makes me worried something got overloaded.
    IG 15 X 30 Rectangle Vinyl Liner Built 1994
    Hayward DE 3620 Vertical Pro Grid
    AquaCal Heat Pump
    18K gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: How can I tell of DE is coming through the returns?
    Sounds to me like you have a suction side leak and those "white streaks" are are bubble streams. Unscrew an eyeball. wrap a knee hi around the threaded end, screw it back in, start the pump and see what you get.
