Thread: AquaLink Z4 and Hayward TriStar Pump Connections
    Jul 2015
    Houston, TX
    1
    I have an AquaLink Z4 Controller and a Hayward TriStar VS Pump. My question is how to connect the pump to the AquaLink for communication. The Hayward manual for the pump shows the below connections. My question is - is how to make these connections to the Z4 Controller? I have copied the a link tot he wiring diagram from the AquaLink Z4 Controller manual also:
    http://www.prolinedist.com/wp-content/uploads/Exploded_Diagram_Z4.pdf
    . Any help that you can provide will be greatly appreciated. Thank you.
    13,500 gallons; In-Ground ; Gunite/Plaster; Hayward Cartridge Filter; Hayward TriStar VS Pump; Pool Built in May 2015; Has Spa with Hayward NG 250,000 BTU Heater; Hayward "The Pool Cleaner" Automatic Cleaner; Use a Zodiac Z4 Automation Controller; Pool filled from Public Water Supply.
    Casey's Avatar
    SW PA
    10,448
    Re: AquaLink Z4 and Hayward TriStar Pump Connections
    Welcome to TFP. Someone should be around to help you.
