Thread: Motor runs...just not when connected to the pump :(
    Aug 2015
    Lewisville, Texas
    1
    Centurion 7-168453-24 and a Challenger Pentair pump
    Motor quit turning....I took it apart from the pump...hooked it back up to electricity and it spun like a top.
    Reassembled and greased everything and...nada. It wants to turn...it's making a noise. With a touch of a screwdriver to the impeller it spins like it's supposed too. Bought a seal kit. Haven't hooked it all back together due to the binding? Issue. Or is it just the pump is toast?
    Help please for a newbie pool owner and expert tinkerer.
    Thank you!!! Dan
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Motor runs...just not when connected to the pump :(
    Hello and Welcome to TFP,
    When you had the motor off did you check to see that pump (not the motor) turned freely with no binding ? If the pump turns freely I would suspect motor being bad. An electric motor can turn with no load on it but still be bad
    Hope that helps. Let us know what you find out
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
