Thread: air jetting out return when increasing pump speed
    Jun 2015
    Oldham, KY
    8
    Is it normal or OK to have air jetting out of one of the returns when I increase the RPM of my VS pool pump? Sometimes see air bubble in pump filter basket, sometimes not. Sometimes air bubbles out of the same return that occasional jets out air when I up the RPMs. Pool contractor said it is normal from time to time.
    In ground fiberglass 26000 gallons. Pentair Intelliflo VS+SVRS pump, Autopilot SWCG w/ Pool Pilot Digital Nano, Polaris 280V vacuum with booster pump. AquaCal SQR166 Super Quiet Icebreaker reverse cycle heat pump.
    May 2014
    SE, Wisconsin
    46
    Re: air jetting out return when increasing pump speed
    Generally when you have air bubbles in the pump basket you have a suction side air leak. The air bubbles coming out the return are being pushed through your filter.
    Do you have any problem priming the pump at low speed?
    20,000 gal, 18 x 36 IG Vinyl, 1.5 HP Hayward 2610x152S two speed, Sta-Rite S870 sand filter, Raypak 265,000 BTU P-R26A-EP-C, TF-100 Test Kit
    Jun 2014
    15,153
    As OldPoolBoy2 was alluding to, here is the TFP link to the Pool School - Suction Side Air Leaks to rule-out any areas where air can enter the system. Having said that though, I have also seen posts that indicate some VS pumps may (on occasion) allow a small amount of air to settle under the pump basket clear lid when on low. This appears to have something to do with the low pressure at times, and the strong force of the pump's "pull" of water actually drawing-down the water level in the pump basket, but not pulling so much water it can keep it full. So when the pump goes to a higher RPM, it pulls enough water into the pump basket to keep it full eliminating all air. I'm not a VS pump owner, but some other forum members may know what I'm talking about and can expand.
    I have a 2 speed pump that seems incredibly strong for my pool. I'm not complaining, but on occasion, I've had champagne-size bubbles exit the same return off & on. Not enough to lose prime to the pump, only to drive me crazy looking for something wrong. After exhausting everything on the suction leak page link above and other ideas I cold find, I just came to realize that is a unique characteristic of my pool.
    So if the air bubbles are not excessive, you're not losing prime to the pump, and it's only happening when you increase the RPM, I would tend to say you should be okay. You can (and should) exhaust everything on the link above, but after that, it may very-well just be a characteristic unique to your pool.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I also see some bubbles in the pump basket when i shift the pump to higher speeds- this leads to some bubbles out of one of the returns, but stops after a short time
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    HMMMM......... carbonated pool water. At least your water won't go flat
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
