Thread: Verify test results
    Jun 2015
    Florida
    74
    Verify test results
    I recently had someone by to "balance" our new pool. I could have done this myself but figured if the builder is covering it, Id let their sub use his chemicals. I tested water this morning at work. I'm a water treatment plant operator and have the best testing equipment money can buy and fresh testing chemicals at my disposal. When I tested this morning, PH was 7.5 and Alk was 90. PH was tested using Hach meter (calibrated before test). Alk was tested by titrating with Bromocresol to an endpoint PH of 4.5 This is THE way to test for alkalinity. Anyways, the pool guy was at house 2 hours later and said he got a PH of 7.9 and alkalinity of 120. How can a guy that does this for a living be this far off? Apparently, he then used acid to bring down suspected "high numbers". Also, I had tests run at Leslie's to have documentation for pebble finish warranty. I got a calcium reading of 300 by titrating using Potassium Hydroxide with a Calver indicator. Shortly after, Leslie's got a reading of 200. The point of this post is, if you get your testing done professionally, don't take their numbers as gospel. Do your own testing and if possible, use a standard to verify the numbers your getting are accurate.
    10k gallon freeform, 3.5-5ft, Jandy 2 speed 1.5HP, Jandy 200sq/ft cartridge, Jandy watercolor LED, 600sq/ft Travertine Decking, 12x7 ledge w/bubbler and umbrella sleeve, 100ft of baby fence with self closing gate, Pebble Sheen Blue Granite w/ablalone shells, Build Start 5/27/15 and completed on 7/15/15.
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    Re: Verify test results
    I guess you're saying testing is testing, right? I mean for waste management testing, it's the same? So my friend's know-it-all husband knows how to test, but doesn't know what to do to treat? Seems like most of what he says is wrong compared with TFP. All he did was test samples, watch Tv and eat. Maybe that's why he doesn't work there anymore?
    Just asking because I could swear he's never tested a water sample in his life, but I know he did!
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    JupPool you're preaching what is taught here
    Never trust pool store results, test your own with a good kit.
    Though most of us will never have the kit access you have. Fun stuff.
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Florida
    74
    Quote Originally Posted by Newpoolcrazy View Post
    Jun 2014
    14,965
    Yes JupPool, exactly why we caution so many members and visitors about having anyone else test their water - pool builder, pool store, or otherwise. You simply won't get the quality testing you deserve unless you have your own proper, reliable test kit.
