Thread: Pipe thread question, not screwing in completely. Is this ok?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    Sorry for the large image...
    does led this adapter need to be screwed in further than I'm able to get it screwed in? I've used liquid Teflon on one of these and pipe seal tape on another and they won't go in all the way, like I was able to do with another one I've already installed (not pictured.)
    Is the seal probably good enough on the left fitting? I'm guessing the right one is no good. Thoughts?
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Pipe thread question, not screwing in completely. Is this ok?
    If it bottoms out you would have it too tight. It should be "roughly" finger tight and then an additional 1.5 turns or so. I've seen many recommendations from 1 to 2 turns, and "finger tight" also varies per person. It takes a little practice sometimes. Using either tape or a sealant the treads are effectively lubricated and easy to over-tighten and create stress and future crack of the female adapter.
    Since it goes to a barbed hose fitting though it's an easy spot to re-try if you have a drip.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    22,553
    Tapered pipe threads are designed to fully seal at about 3/4ths engaged. If you overnighten them it can split the female part.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Some PVC fittings aren't tapered. I know the ones for electrical conduit aren't. You might have gotten one of those and that's why the other fittings went together farther. I use that trick to create low cost bulkhead fittings.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    Camarillo
    3
    I'm new here so not sure if URL's are ok.
    Try this link at LASCO, one of the biggest manufacturers of fittings. Basically what NeedMoreSun said is exactly correct.
