Thread: Bleach Jug sizes now available in 121 ounce volume
    Jul 2015
    Tallahassee/Havana/Florida
    18
    I am able to buy bleach in 121 ounce size containers now from local retailers. I also noted that in the PoolMath FC portion of the test, the only selections in the drop down window do not contain this option.
    Is there a way to modify or add it to the calculation drop down menu?
    Also I am unable to add an attachment here?
    23,000 Gallon In Ground Pool Masonry Plaster finish and 36" surrounding walk.
    Sand filter by Triton II w/1HP pump. Using K2005 Taylor Complete (High) Test Kit
    Use: RV Camp Ground Medium-Heavy load w/approximately 65 campsites. Water is supplied from well on property.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bleach Jug sizes now available in 121 ounce volume
    121oz is available on the Pool Math drop down menu. It's the last option
