Results 1 to 8 of 8
Thread: The ants have discovered my salt water pool...
    kristenerika's Avatar
    Jul 2015
    Waco TX
    19
    ...and now we have an infestation of Biblical plague proportions.
    I think that this is our problem: Ants Prefer Salt over Sugar
    On Tuesday evening I noticed a few ants near one of our skimmers. Last night (Wednesday) there were tens of thousands of them EVERYWHERE, rendering our deck and pool unusable. Two of my kids got eaten alive by them before we realized what was happening.
    The exterminator is on the way today, but has anyone else experienced this? They seem to be very attracted to the salt water. I've never seen ants swarm like this except for around something sweet spilled on the ground.
    Any hints or tips for managing/avoiding this situation would be appreciated. In Texas a completely pesticide-free lifestyle is not possible, but we like to use them as sparingly as possible.
    Brand new pool owner -- first day of swimming July 4, 2015! 22,000 gallon custom (14 x 40 rectangle) gunite in-ground pool with Stonescape plaster (Irish Mist). Hayward Pro Series sand filter (S244T2), Hayward TriStar pump (SP3207X10), Hayward Goldline Turbo Cell T-Cell-15 SWCG with Pro Logic control panel. Taylor K2006-C test kit. Mom to three boys, eight rescue parrots, and two dogs.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: The ants have discovered my salt water pool...
    Adding borates to your pool can discourage insects as well as help to stabilize pH. However, since I see that you have two dogs, it's not a good combination for dogs that like to sip from the pool as it can also make them sick. There was nothing in the skimmer that was attracting them? You could try an experiment with a salt block that's normally intended for cattle placed somewhere away from the pool.
    Isolated Spa - 345 Gallons
    Jul 2015
    Waco TX
    19
    Thanks for your reply, Joel.
    No, there wasn't anything else in the skimmer.
    Fortunately we have trained the dogs to stay away from the pool and they don't drink from it, so borates should be fine. I was holding off on adding them until I can get my high TA under control, but the ant situation may prompt me to add sooner (we typically have a fair amount of rain in the early fall, so that should take care of my TA problem).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Also try spraying home defense around the perimeter of the pool/deck.
    Jul 2015
    Central Valley CA
    1,107
    I prefer Suspend Polyzone approx. $35 ordered from the web. If you can find the hill this stuff will eliminate them completely in a single application, but even if you can't it will usually keep them at bay for 3 to 4 weeks.
    Dec 2012
    Manassas Park, VA
    206
    I am not sure if this will work for you but I have had ants around my house and pool for a while, not nearly as many as you described. I also have an exterminator service that I would call out once a week to spray for the ants and it did not seem to work. I purchased some Terro liquid ant bait. This resolve in 2 days what weeks of exterminators could not.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Late to the party, but I can also vouch for the Terro Liquid Ant Bait, Great Stuff!
    17.5K IG Pool with Spa spillover and fountain, Plaster Finish, Purex Triton CC420 Cartridge Filter, Pentair Intelliflo XF VS motor, Laars LX GasHeater, Polaris 360
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I also treat all around the pool with Home Defense. Couple of times a season seems to do it in my case
    Divin Dave,
