Results 1 to 12 of 12
Thread: So frustrated w/ this FOAM!!!!
    Jul 2015
    SC
    20
    I've been dealing with this stuff for a few weeks now. My water is clear as long as I do ⬇️this almost everyday
    Doing this almost daily: I am cleaning the filters by hosing off then soaking in bleach & water. Using a Magic Eraser to wipe the thin brown line @ water level then skim the FOAM 😠 stuff out. Clear water starts to filter back into the pool. I check my levels and add what is needed. 24 hrs later the foam starts coming from the hose again. 😒
    I've been reading on here a ton & have a much better grasp on all this, but this is driving me crazy!
    Jun 2015
    Raleigh
    357
    Re: So frustrated w/ this FOAM!!!!
    Do you have a test kit and can post your current chemistry levels?
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    May 2015
    Manalapan, NJ
    1
    Are you using splash-free bleach?
    Jul 2015
    SC
    20
    Well Cl is at 0 now😠
    pH 8.2
    TA 80
    😳 um lol yes I am.
    Jun 2010
    Northern Vermont
    31
    Your numbers will be helpful here to see what's going on. Once you post those you'll get concrete guidance on what is going on. In the mean time I'm wondering 2 things:
    1. The Magic Eraser has cleaning solution in it that could then find it's way back into the pool.
    2. Algaecide: I recently had a problem using a linear quat (not polyquat) algaecide and that produced foam when overused. If you are using algaecide, perhaps stop. This will dissipate over time with balanced water and sticking with straight chlorine to kill the algae in the pool.
    -Backyardchemist
    25,000 Gallon, IG, vinyl, Pentair Whisperflo WFDS-24 (2-speed), 8 Rainbow M Series cartridge filters, unheated
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by SC83 View Post
    Well Cl is at 0 now
    pH 8.2
    TA 80
     um lol yes I am.
    Splash free bleach is causing the foaming. Make sure you don't buy that stuff..... just regular, unscented, bleach......
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by ewkearns View Post
    Yep. Splash-free bleach contains surfactants (read: detergent) that help give it the splashless qualities but will foam like crazy with aeration. Foam should go away over time as you use the plain old bleach. Stick to using the splashless with laundry.
    Isolated Spa - 345 Gallons
    Jul 2015
    SC
    20
    Awesome thanks y'all!!!!
    Oh and could this be related to the thin brown line at the water level? It's only there when the foam is pumping into the pool.
    Feb 2014
    Central Minnesota
    5,080
    It could be that the surfactants you have added unintentionally are removing some biofilms from your plumbing or reacting with things trapped in your filter. I still don't know if your referring to a spa or pool. That would help. Judging by your filter maintenance description and scrubbing the water line, I'm guessing spa or small pool?
    Jul 2015
    SC
    20
    Oops still new here & haven't added that to my signature.
    It's an Intex 14x48 &
    I'm using the pump that came with it
    Feb 2014
    Central Minnesota
    5,080
    Then it's likely that the surfactants in the splashless bleach are both causing the foam and pulling the residues (sunscreen, oils, perhaps plumbing biofilms) from your filter and plumbing out and the foam is depositing them on the water line.
    Jul 2015
    SC
    20
    Thanks again!!!!
