Thread: low circulation pressure
    Hi everyone - I am new to pool care, and have been backwashing once a month or so over the winter (about 5 backwashes). I have a DE filter. I have noticed that the suction pressure is dropping. I have a fountain and the pressure on the flow is marginal. In my skimmers, when I reach into them with the pump on, I cannot feel any suction. My filter gauge reads 0, but could be broken. I just read about adding DE after each backwash, which I have not done all winter. I have cleaned the filter basket (which was heavily clogged with earthworms and stuff). Any ideas what to do next? Trying to avoid actually manually cleaning the grids unless absolutely necessary. They are new grids and were installed last May.
    24,400 gallon irregular shaped gunite chlorine pool
    Purex-Triton nautilus NS-36 DE filter;Pentair SM-20-2 multivalve
    MagneTek Centurion Switchless motor 1.5 HP
    Polaris
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: low circulation pressure
    You need to manually clean the grids. When you run a DE filter without DE, the grids themselves become clogged. I'd suggest you do it on a day that a pool store is open so you can get replacements before you put it back together if needed.
    Is this something I need to get a professional to do? Or can I muddle through it myself? Filter is a Purex-Triton Nautilus FNS filter.
    Polaris
    Butterfly's Avatar
    South Carolina
    10,045
    Hi rohan and welcome to the forum
    Check out this post by waste (Ted) use-and-care-for-de-filters-t4086.html
    You're done SLAMing when:
    I don't know if it will work for you but I use the magilube to seal all of the gaskets. The pump basket gasket, the pump gasket. In my system, those are notorious for letting air in an pressure low.
    Scott
    1) 24000 gal
    2) DE filter
    3) IG
    4) plaster
    5) 1 hp
