Results 1 to 13 of 13
Thread: Show-n-tell: Community Pool Test Numbers
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    In the heat of yesterday's late afternoon sun, the kids and I left our pool and ventured across the street to our community pool, which is cared for by the HoA. Just for fun, I brought my TF-100 along to see what I could learn. This pool is relatively new and was put into service just about a year ago. Other than there being a bit of dirt/sand on the blindingly-white bottom, the pool looked great and the water was sparklingly spectacular. Then I started characterizing the chemistry:
    pH 8.2
    FC 3.0
    CC 0
    CH 475
    Alk 90
    CYA 75
    I'm a bit surprised by the pH. I have a hard time keeping mine within range, but I don't think I've ever seen 8.2 since startup. CH is the most inexplicable. I assume they use the same water that I do, and I have to add a fair amount of minerals to keep my calcium levels correct (fill water ~150 or so).
    Since I know what I'm talking about (Thanks TFP!!!), the most concerning thing to me is the chlorine/stabilizer ratio. I would be targeting a minimum of 5-6 with CYA at 75, but the pool looks great. Is it correct to assume that 3.0 is high enough for disinfection? I'm assuming that they're using some sort of algae treatment to keep the pool looking so great with such low FC levels.
    Anybody else take their chemistry fun set over to their local public pools and see what's happening?
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Re: Show-n-tell: Community Pool Test Numbers
    Just think.......the PH could be OVER 8.2
    The CH could be from the plaster if it really that new.
    The FC and CYA could be a problem BUT what was it first thing in the morning and during the night. The FC of 3 in the late,hot,high bather load could explain the 3.
    Kim
    Donldson's Avatar
    NW Ohio
    2,897
    That FC should be alright at 75 CYA to disinfect, bacteria and viruses are killed at much lower chlorine levels than algae. Not that I would want to get in if it was full of people. You are probably right, I would say either algaecide or phosphate remover.
    I can't test public pools, it would just cause me to pull my daughter out of it in terror. I don't want to be "that guy."
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    15,155
    Kind of like having the opportunity to inspect the kitchen at your favorite restaurant. Some things are better left un-seen.
    zombiejeep's Avatar
    Jun 2015
    Nebraska
    39
    Quote Originally Posted by Donldson View Post
    ....I can't test public pools, it would just cause me to pull my daughter out of it in terror. I don't want to be "that guy."....
    Same.
    Still very new to TFP, but I know just enough to be dangerous. I would hate to know what we were swimming in!
    21' Revelation AGP ~10,500 gal, Pentair SD60 Sand Filter w/ 1 1/2 HP Dynamo Pump, TF-100 Kit
    Installed 07/25/2015 with city water.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by kimkats View Post
    No problem with bather load. This was late afternoon, heat index 108°. I've never seen any more than 1 person at a time in our community pool. (That's my twins getting ready to jump in the "deep" end....)
    Quote Originally Posted by Texas Splash View Post
    The community pool opened up in May. I've been able to resist the urge to take my test kit over for the last 3 months. Yesterday I succumbed to the temptation. Time to hop back on the wagon....
    Mar 2007
    San Rafael, CA USA
    12,082
    Or they could be lucky that their water is low in algae nutrients and that they don't have phosphates in the fill water with lots of evaporation and refill. There are many pool owners who use Trichlor regularly, have high CYA, don't use supplemental products (e.g. algaecide or phosphate remover) and don't have problems in their pools. That's why they don't always believe what we talk about here. It is not necessary to use algaecide or phosphate remover to have pool water that doesn't grow algae quickly in spite of low FC/CYA levels; it can be naturally (initially) low in algae nutrients.
    Jan 2014
    Buckeye AZ
    807
    Are you sure they don't have any form of supplemental treatment? I doubt you were allowed to look in the pumping room.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jul 2012
    Tallahassee, FL
    30,535
    That is a pretty pool. I like the set up with the tanning ledge and jumping off wall!
    Kim
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    My bet is they shock it regularly with cal hypo. Lets them get away with the lower chlorine level and explains the high calcium level.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Looks like a nice pool and big. Maybe the PH is so high because of those 3 water jet thingies? We have a nearby community pool but I'd be too afraid to find out what the chemistry is. You're brave, Jay I think I've turned into a snob. Ever since we got a pool, I won't swim in a public pool.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by mickey4paws View Post
    Your point is exactly why I decided to test the water. Sometimes the family likes to go over to the public pool (beats the heck outta me as to why!), so I wanted to see what we're getting into over there. For the single data point that I now have, the water seems to be OK for swimming.
    So here's the funny part. I have an SWG, and sometimes I get tired of the salty taste of my pool water. After swimming a few laps in the community pool (decidedly NOT SWG), I realized the water has such a "flat" taste. I couldn't wait to get back to my backyard paradise for the salty taste and silky feeling. I guess TFP has made me into a pool snob.
    Jul 2012
    Central Texas
    436
    Sidebar...I was swimming last week in Jamaica and Cozumel and was longing for the 'normal' salt water taste rather than the stuff that burned my throat.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
