Thread: Copper in pool
    Aug 2015
    Lexington SC
    1
    Copper in pool
    I recently noticed brown stains on my vents. Tested with vitamin c tablets and it cleared the stains. I have been placing socks over the vents to get rid of iron but this seems to be very slow paced. My water is crystal clear. I also have been struggling with my pH balance. Can't semester to get it above 6.4. Could the iron keep pH out of balance? I have an in ground pool 26000 gallons with vinyl lining. Thanks for your help!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Copper in pool
    Welcome to TFP!
    How are you measuring pH at 6.4? That is extremely low. The iron has no effect on the pH. What is your TA?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Copper in pool
    Hope OP return, 6.4 is very low!!!
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
