Thread: Troubleshooting Jandy Stealth 2speed pump
    San Diego
    18
    Hi All!
    We have just over a 2 year old pool. I Noticed this afternoon that my pump wasn't running, so I went out to see what' was going on. I found that the circuit breaker had tripped and proceeded to reset. This was about half way through the daily timer job, so the timer kicked back on and attempted to start the pump. However, all that I heard was a humming sound for a few seconds and then all quiet. This then repeated again and realizing there was a problem I shut off the power. Took out the baskets and check for blockage, nothing. Disconnected the line from pump to filter and it appeared to be clear as well. I tried to see if there was a Manila way to spin the propeller, but it doesn't appear to be easily accessible.
    Hoping someone may have some guidance on next steps, and really hoping it's a simple fix! 😊
    Thanks in advance for any help!
    San Diego
    18
    Re: Troubleshooting Jandy Stealth 2speed pump
    Just found this thread, will check out the suggestions found here pool pump makes humming noise and does not pump
    Jun 2012
    western NY
    1,559
    If you can access the back of the motor there may be a slot in the motor shaft that you can turn it with a screwdriver. It should spin free. If so I would suspect a stuck start switch on the back side of the motor or a bad start capacitor
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
