Thread: Party on Saturday -- add extra chlorine in advance? After?
    Eva's Avatar
    Jun 2015
    Tucson AZ
    24
    Hi -- I saw mention of this somewhere on the site and now can't find it. I have been maintaining my outdoor, but covered by a roof and a pool cover, pool at about 3 -4 FC, using liquid chlorine. The pH is about 7.6. I am raising the CYA from 20 to 30. The entire added 14 Oz by volume of CYA dissolved from the sock in 24h, but I haven't measured it yet to see if I've hit 30.
    So, I'm having a big pool party on Saturday. Maybe as many as 25 people will swim. Some kids. Should I raise my FC in advance? Any other things I should do in advance or after?
    Many thanks,
    Eva
    Eva in Tucson, 9800 gallons IG, under full roof, also with vinyl cover, pebblefina, Pentair 1 HP pump, Pentair 320 sq ft cartridge, Aquacomfort 1150 heat pump, ozonator, Maytronics Dolphin Triton robot. Brand New June 22, 2015!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Party on Saturday -- add extra chlorine in advance? After?
    Hi Eva,
    It would be a good idea to raise your FC by probably 3 ppm about an hour before the party starts.
    After its over, test the FC and make any adjustment that you need to get it back to normal level of 3-4.
    Thats really about it.
    Have fun with your party!
    Divin Dave,
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Yes, raise it up a couple or three ppm more than normal before and check it after the party.
