Results 1 to 13 of 13
Thread: Full Test Results
    Jun 2015
    madisonville, tx
    35
    Full Test Results
    So I have to admit, I fell off the TFP wagon for about two weeks. Been fighting a pump issue that I finally got resolved tonight. (I have to say, those that watch the testing and balancing side of this forum are considerably more responsive than the equipment side of the forum. Could be though that my question was so elementary that they assumed I would just figure it out). Anyway, with the help of TFP, this is probably the first time in 4 years that the floor of the deep end of my pool can be seen. After the two week hiatus over my pump, here are my test results.
    FC, TC, & CC - 0
    CYA - 5 or less
    PH -8.4
    TA - 240
    CH - 75
    Though the pool is clear, I can see algae spots forming down the sides and around the returns. I've been fighting keeping CYA in the pool, but may have dropped due to the significant drain while repairing pump. I'm concerned that the TA is too high and the CH is too low. I need to get bleach into it ASAP as well as a gal of muriatic. I cant get it in my sig, but it's a 40k gal in ground plaster pool with a Hayward Sand Filter and a pentair 2hp pump. Thoughts?
    Aug 2014
    Northern IL
    4,615
    Re: Full Test Results
    Ignore CH and TA for now. Get those other numbers in line. To prepare for another slam.
    Aug 2014
    Shallotte, NC
    693
    Go get some muriatic acid, you are going to need some. First, get pH under control.... and that can be done in 2-3 hours. Then, SLAM the pool until clear.
    Once clear, you need to bring the CYA up, the TA down (and that, frankly, will take a while), and boost your CH up.
    PS
    You have a pH of 8.0+, the test isn't accurate over that amount. You'll probably need 2 gallons of MA to get started(not all at once).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by sealy99 View Post
    Just as fyi, most of the primary responders look at every new thread that posts regardless of what forum it is posted to. Everyone on TFP maintains pool water. Far fewer repair or replace their own equipment. Far fewer still troubleshoot their own electrical. And fewer still are confident enough in their own electrical knowledge to advise another person on how to troubleshoot an electrical problem without seeing exactly what is going on.
    Glad you got your pump issue resolved. And glad that TFP has helped you get your pool water under control.
    Aug 2014
    Shallotte, NC
    693
    I didn't see your request for help on the pump, but if I had, all I could have done is ask for pictures and a more thorough explanation..... The danger in trying to advise on issues like that are, if you don't know what you did wrong, you might not be the best person to describe the current situation..... IOW, it would be w-a-a-a-a-y-y too easy to give you bad advice....
    Jun 2015
    madisonville, tx
    35
    Quote Originally Posted by pooldv View Post
    That makes sense. Turns out after tracing wires, looking for a GFI issue, replacing my timer, and the pool sitting for a week with no circulation, it was just a burned spot in the motor. Rotated the shaft a quarter turn, hit the power, and it fired right up. Preparing to slam again. Hopefully it goes much faster this time. On a side note, is there such a thing as liquid CYA or something that quickly disolves?
    Aug 2014
    Northern IL
    4,615
    Yes, there is liquid CYA. People don't usually recommend it because it is more expensive.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    FC, TC, & CC - 0
    CYA - 5 or less
    PH -8.4
    TA - 240
    CH - 75
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    How did you get that CYA reading? What test kit are you using?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    madisonville, tx
    35
    TF-100. Don't have it in front of me at the moment, but I believe the lowest reading on the indicator is ten. At that level, I can just barely make out the dot on the bottom of vial
    DFW, TX
    24,514
    I've never heard of that with a pump. Very interesting.
    The CYA tube reads high at the bottom and low at the top. Sounds like CYA is high, not low.
    Jun 2015
    madisonville, tx
    35
    What I meant was it indicates a level as low as 10. When I checked it again this morning, it was at 0. Filled the CYA tube to the top with the mixture of water and solution and could still see the black dot clearly at the bottom. Added 4 lbs of cya at the skimmers with socks. It'll prob take a couple of days to disolve. Pool is clear, but a tremendous amount of algae spots across the bottom and on the walls. Scrubbing, vacuuming, and slamming now.
    DFW, TX
    24,514
    Good plan. Ok, I agree with your CYA test results. That is how my pool does algae, clear water and spots of algae. Be sure to check under ladder rungs, behind lights and in pool cleaners. Those are places where algae likes to hide. Assume that the CYA in the sock is in the pool and set the chlorine level accordingly, Chlorine CYA Chart
    Aug 2014
    Northern IL
    4,615
    Agreed on the lights! I put off doing it this spring because the water was so cold. I just did them today. Yuck. Eeeww.
