Page 1 of 4 1234 LastLast
Results 1 to 20 of 67
Thread: 1st results!
    bryansanders's Avatar
    Jul 2015
    Green Country, OK
    70
    1st results!
    Ok so I got the TF-100 in today and tested my untouched pool and this is what I got:
    FC 0
    CC 0
    PH 7
    TA 5 drops pink up to 20 drops pink, stayed the same... so 50?
    CH 75
    CYA 20
    Looks like I need a little bit of everything!
    Aqua Leader 33' x 54" AG, 28+k, AquaTools 2HP 2SP pump, AquaTools 200lb Sand filter, Liquid Chlorine, TF-100
    Installed 8.1.15, rural water, direct sunlight 8hrs/day, Aquabot Breeze XLS
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: 1st results!
    All I see that you need is a little bit of CYA and some bleach.
    then
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: 1st results!
    Let's get that PH up a bit too please. That CYA level is too low for OK. 40 or 50 I'd say. See the cya/chlorine chart in Pool School.
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Ok so according to poolmath I need to add the following:
    1 gallon and 3 cups of Liquid Chlorine
    4 lbs 3 oz of stablilizer (sock method)
    and 6 lbs 3 oz of borax
    Am I correct?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: 1st results!
    Good plan! The CYA comes in 4lb jugs, I wouldn't buy another for the extra 3 oz. In this case you might use soda ash to raise your PH and raise the TA a bit at the same time. Wouldn't hurt to get it to 60 or so.
    Have you seen my favorite chemical page?
    zombiejeep's Avatar
    Jun 2015
    Nebraska
    39
    Re: 1st results!
    Quote Originally Posted by woodyp View Post
    I don't mean to hijack, but how do you know that for the specific location of OK? I missed that in pool school. Forgive me, I am still trying to learn. I see the CYA chart, but nothing about location.
    21' Revelation AGP ~10,500 gal, Pentair SD60 Sand Filter w/ 1 1/2 HP Dynamo Pump, TF-100 Kit
    Installed 07/25/2015 with city water.
    DFW, TX
    24,509
    Re: 1st results!
    All of OK is hot and sunny so the higher end of the recommended CYA range is more appropriate. Sort of like the planting hardiness zones. Up north starts at 30 and down south is 50.
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    I'll keep that noted pooldv! Always appreciate the advice. Ok so once I add the needed chems, how long do I wait to test again? and do I perform all the tests?
    zombiejeep's Avatar
    Jun 2015
    Nebraska
    39
    Re: 1st results!
    Quote Originally Posted by pooldv View Post
    duh. I was overthinking it. Got it now, thank you!
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Soda ash, how much, the remaining 3 oz?
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    ...ok so I put in 1 gal 3 oz of bleach, a sock full of stabilizer 4 lbs (wont fit in my skimmer, so it is hanging in the water by the skimmer), and 3 lbs 5 oz of washing soda (dissolved in pale, then slowing poured in).
    Running the pump on high, 14 psi..
    When do I test again, and do I test all but the CYA??
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: 1st results!
    You can test for all but CYA an hour after adding.
    CYA you need to wait a week for full effect, so hold off testing that, it's a waste of reagents.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    After 2 hours of adding the above, I tested TC, pH, FC, CC, and TA...
    Yesterday to Today
    FC 0 to 3.5
    CC 0 to .5
    TC 0 to 4
    TA 50 to 60
    PH 7 to 8.1
    On the right track??
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: 1st results!
    Looking better.
    FC is ok but will have to be increasd as CYA increases.
    pH overshot the mark a little but don't overdo any further adjustment as the CYA will bring this down some.
    TA is a little low but while there are so many things changing I would not worry about it too much yet.
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Ok. Great to hear. So what's my next step...wait a week to check the CYA...or perform the same test tomorrow evening?
    Another thing, should I keep the pump on high?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: 1st results!
    Test tomorrow for FC & pH for sure.
    You will likely need to add bleach and I will predict your pH will drift a little lower.
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Sounds good, I'll post the results. Gonna be hot the next few days.
    DFW, TX
    24,509
    Re: 1st results!
    Run the pump on low, pretty much always run it on low unless you are vacuuming or something.
    Go ahead and assume that however much cya you out in the sock is in the pool and chlorinate accordingly, Chlorine CYA Chart
    Here is a schedule, Pool School - Basic Pool Care Schedule
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Retest FC 0 pH 7.7, pool walls were slimy last night, pretty sure that's where my clorine went...
    Did pool math and added the required amount to get back to par...we'll see in an hour!
  20. Back To Top    #20
    Jul 2015
    Green Country, OK
    70
    Re: 1st results!
    Now we are at:
    FC 4
    PH 7.7
    TA 70
    CYA Sock still dissolving.
