Thread: Can't Find Skimmer Cover Old 15" metal skimmer
    Feb 2013
    Seattle/WA
    6
    I have an old metal skimmer from around 1960 and cant find a 15" skimmer cover. I have spent hours online searching. Any ideas?WP_20150611_004.jpgWP_20150611_012.jpg
    BBB, Old 30,000 IG Plaster, Pentair Clean and Clear, bleeping SVRS Pentair Intelliflo, 1.5 inch plumbing, H2otsun Solar 15' above pump with SWIM PC. Been upgrading as budget allows. Issues: underslab suction side leak, missing odd size skimmer lid, painted surface failing, non functional light, clogged main drain, missing main drain cover, winter loop loc style cover duct tape included, questionable fence surrounding yard. Happy new pool owner
    Apr 2013
    Sacramento, CA
    2,769
    Re: Can't Find Skimmer Cover Old 15" metal skimmer
    Start calling independent pool stores. Start in Seattle and move outward. I'd call in the LA area after Seattle.
    For example in Sacramento I'd start with Best Pool Supply.
    Just call and explain the problem -- Its amazing what some of the old pool guys know and have in their shops.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Hit some of these site's & you may find a 15"
    metal skimmer lid - Google Search
    You could also go to a local PlexiGlass shop and see if they have something strong enough they can cut for you?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
