Results 1 to 10 of 10
Thread: Whisperflo Motor just went out (I think), advice for replacement.
    Jun 2010
    Las Vegas, NV
    7
    Firstly equipment is approximately 13 years old. My 2HP single speed motor just went out I think, haven't had a chance to pull it from the pump to check rotation etc. Wife said the pump was really noisy so went out to investigate and saw some white smoke coming from the general area then the equipment shut down. Now the motor just hums for about 15s then trips the breaker. I changed the capacitor out last year, I don't remember the exact symptoms when that went bad.
    The label on the motor is a little messed up, hopefully there is enough information visible that it can be accurately identified. 20150805_121225.jpg20150805_121234.jpg
    My pool is 10K gallons, compool 3400, in floor cleaning, aquarite SWCG, solar, spa and heater. I do notice when my filter is getting dirty that there is less pressure for the in floor (the heads don't come up enough to rotate on the way down).
    I don't mind getting a new motor, but I figured that since I am doing it I may as well look at upgrading to a 2-speed or even a VS if they are going to keep my pool clean and save some money on electricity costs down the road.
    Can anyone provide some advice/recommendations on a replacement motor ? Will I get any benefits from a 2-speed or VS ?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Whisperflo Motor just went out (I think), advice for replacement.
    the people with motor knowledge will need the information of the old motor...
    Jun 2010
    Las Vegas, NV
    7
    Added images of labels on current motor.
    10K gallon
    Compool 3400, Aquarite SWCG, In Floor Cleaner
    Pentair Minimax NT Heater and Solar
    Spa
    Jun 2015
    Wildomar, California
    423
    Hi Ozzzz. So your 2hp Whisperflo motor looks like it's dead? Smoke usually means so. You have a 2hp square flange motor. If you're thinking long term, a VSP pump is a great choice. It is definitely a money saver and Pentair makes what I think is the best one out there. But research the pump and draw your own conclusions, then research price, which can vary a lot between pool stores and online
    Jun 2010
    Las Vegas, NV
    7
    The price doesn't bother me, I am comfortable paying for something that has value. I just don't want to potentially waste money on a VS if I have to keep it on full speed all the time to run the infloor.
    Also, can I just put a VS motor on my pump or do I need to change the motor and pump ?
    10K gallon
    Spa
    Jun 2010
    Las Vegas, NV
    7
    Shaft turns, but makes a bit of a grinding sounding and it certainly doesnt turn freely.
    Also, I cant for the life of me get the bottom two bolts out that hold the motor to the seal plate !!! I've sprayed copious amounts of penetrating oil, I'll spray some more tonight and then in the morning and see if that helps.
    I guess if I cant get the seal plate off I may as well get a completely new pump, which I was hoping to avoid so I didn't have to touch any of the plumbing !
    10K gallon
    Spa
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Double your leverage with a second wrench as this stolen image shows
    And if it's in your paws, haul the thing over to a garage somewhere and have someone zap the bolts off with an air wrench. I imagine a few ice cold waters or gatorades would suffice.
    Definitely go with a new variable speed pump. I wouldn't try to rebuild that old WhisperFlo.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Ozzzz666 View Post
    +1. Given the in-floor and your location, a VS would probably end up costing more over the life of the pump than a two speed or even a high efficiency single speed. However, VS pump rebates from your local power company might help even it out some.
    Mark
    Mar 2015
    Las Vegas NV
    460
    Ozzzzz, I just happen to have a 3hp whisperflo I'm looking to sell here in Vegas. Here are the details of why I'm selling it http://www.troublefreepool.com/threa...rand-New-Build , maybe we can help each other out. Sent you a p.m.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
