Thread: Need Help Removing Jet Fittings
    Aug 2015
    Dallas
    2
    Hi all, new here. I'm trying to attach an aerator to my pool to cool it down. My problem is I can't figure out how to unscrew my jet fittings - they're flush with the wall with 2 little plastic notches sticking out. I'm afraid a screwdriver will break the notch off, is there a tool for this? Any advice is appreciated, thank you in advance! Pics below:
    Jet 1:
    Jet 2:
    Re: Need Help Removing Jet Fittings
    Hey Jody. Might try some channel locks on it.
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    You may need something like this tool to unscrew the fitting.
    Amazon.com : G Garden
    Love TFP? Become a
    TFP Supporter!
    Aug 2015
    Dallas
    2
    Thanks guys. Those are flush with the wall - channel locks or pliers will not work. I tried turning those raised notches gently with a screwdriver and my fingers and they aren't budging. They've been in that wall since 2006 and are brittle - they're chipping off with any sort of pressure. I'll just call a company to come replace these things with normal jet fittings. Thanks
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    I got mine with a pair of needle nose pliers.
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
