Thread: CYA not coming up
    Jun 2013
    Philadelphia, PA
    143
    CYA not coming up
    My CYA was getting a bit low (Seems that's the only chemical I add from year to year.) Everything else really stays in check.
    So I was around 50PPM. Based on my pool size, I added 34oz by weight of CYA (I bought this CYA the first summer I had the pool, so it's now three years old - could it just be old and losing its strength?)
    I add the CYA by slow pouring it down the skimmer. I've tried the socks, pantyhose, etc. Never seems to work well for me. So I always FIRST clean my cartridge filter, then pour it SLOWLY down the skimmer, then check it a week later (And do NOT clean the filter between.)
    After a week, I went from 50-60ppm. Huh? It DEFINITELY lowered my pH as I was at 7.5 and by the end of the week I was down to 7.2.
    Any thoughts?
    At the time I added the CYA, these were my readings -
    FC 8
    CC <0.5
    pH 7.5
    TA 80
    CH 200
    CYA 50
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA not coming up
    The inaccuracies of the CYA test could easily result in a 20ppm error in your CYA change. That's why we usually recommend you add part of what you think you need and then retest after a week.
    Jun 2013
    Philadelphia, PA
    143
    Quote Originally Posted by JohnT View Post
    Really? A 20ppm error? Wow! Also wonder if it's an issue because I have REALLY good eyes and can really see that dot in the Taylor test!
    Anyway, I've tested twice; once a week after adding, and now another week later. Both times 50ppm. Are you saying the error is because we're simply eyeing it up or. . .? Last year I was 70-80 no problem.
    TFT 100
    Jun 2013
    Philadelphia, PA
    143
    Also, quick follow-up - should I assume the 50PPM I've gotten now is somewhat accurate and I should plan to add more CYA?
    TFT 100
    SW Indiana
    9,199
    Quote Originally Posted by TroubleFreePat View Post
    At best the test is plus or minus 10ppm. I don't know if it's that good on the low end. If you think your reading is good, I'd go for another 10ppm and see where it goes.
