Thread: question about pool pump pluming
    May 2015
    Spring Texas
    22
    I recently replaced an old pump with a variable pump. But I am now wondering if I should have increased the length of the output tubing. I basically kept the previous dimensions. The variable pump manual, called for 12" minimal from the inlet side, nothing else was mentioned as far as the output. Just wondering if it's too short and could cause the multi port gasket to fail. Input would be much appreciated.
    10" of out pipe to the multi port after the 90" elbow
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Re: question about pool pump pluming
    If you count the length of the vertical pipe, you have 12" beat by quite a bit. Did they specify 12" horizontal, or just 12" total ?
    If it pumps OK, I wouldn't worry about it.
    P.S.- I would have put a union in the vertical run to make removing the pump easier.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Jun 2015
    Raleigh
    357
    Quote Originally Posted by Thimble View Post
    Agreed on union.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    May 2015
    Spring Texas
    22
    Cool , about 14" going up and 10" after the elbow. yeah the pump came with unions for both inlet and outlet . So I am good on that. Thx for your help
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    do you have the pump mounted on anything or just on the concrete? putting something underneath will help keep noise down, etc
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
