Results 1 to 7 of 7
Thread: First pool, how long to run the SWG each day?
    Jul 2015
    Bridgewater, Virginia
    17
    Hi!
    We just put our pool up, finished filling yesterday. I want to know how long does everyone run their SWG each day for a pool with about 13,200 gals of water? How about the filter? How long should that be running?
    I've tested the water and here are my results
    FC-4.5
    C-0
    PH-7.2
    TA-90
    CH-60
    I know i need to adjust the PH and TA, could you please help me get these numbers to where they should be! Thanks!
    AG 24' by 52" (13,600 Gallons), Hayward vari-flo XL valve sand filter-S190TSCP, Hayward power-flo LX pump-1HP.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: First pool, how long to run the SWG each day?
    Enough to where it maintains you an Fc of about 4. Depends on the size of your cell mostly. We recommend one twice the size of your pool gallons a least.
    Jun 2014
    14,957
    While you wait for general replies from other members, I thought you might want to see these pages if you haven't already:
    Pool School - Salt Water Chlorine Generators
    Pool School - Water Balance for SWGs
    Pool School - Determine Pump Run Time
    Hope this helps. Have a nice day!
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Basically, I set up my pump at the rpm that would be most efficient to cycle our water which requires about an 11 hour run time for me. Then I adjusted my SWG accordingly, which was 60% for our pool.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    PH is OK and TA is fine. Maintain your PH between 7.2 and 7.8 and let your TA be what it wants to be, it is close enough to in-range.
    What is your CYA level? That determines your target chlorine level on the Chlorine CYA Chart. It will take some experimenting to figure out run time and percentage. I'm at 60% and 8 or 9 hours right now. With 70 CYA and FC target of 9. And of course it is HOT and sunny here right now and we swim every day.
    This is a great page to read, Pool School - ABCs of Pool Water Chemistry
    Jul 2015
    17
    Don't know the CYA yet, as we just filled the pool yesterday and there was none in the water, but I did add about 5lbs of CYA yesterday, via sock at the return. It was all dissolved by lunch today. So I guess next Tuesday I will know where it's at. But I'm thinking I need to add more cya.
    DFW, TX
    24,450
    Poolmath is your friend. At the bottom is a section called Effects of adding chemicals. It says that 80oz will raise CYA 44 in 13, 600 gallons. That is a good CYA number for your location. Assume it is in there and chlorinate accordingly. Chlorine CYA Chart
