Thread: Pool Light Not Working...BULB MAYBE??
    Pool is 6 yrs old but light has been used very,very little. I was hoping for something easy so I replaced the GFI breaker and on/off switch for the light. No luck,, light is still out. Got to suspect the bulb now. Can someone tell me the procedures for changing the bulb ?? I'm not very experienced with electric problems but I did replace the circulating motor and fan blade on a 5 ton gas pac with no major problems. I do know the #1 rule, electricity will bite you!! turn off all power before doing anything,,,, thanks for the help.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    30,431
    Re: Pool Light Not Working...BULB MAYBE??
    Nor sure what bulb you are talking about....got a pic?
    Hayward underwater light I think it's series SP0580
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Is it 12v or 120v? Some 12v transformers have a fuse. Check you tube for pool light replacement.
    You might be able to get a bulb at home depot.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    That is an AstroLight. Here is the manual for that light.
    http://www.hayward-pool.com/pdf/manu...ies-SP05xx.pdf
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
