Thread: What the TFP Method Has Done to Me
    Nighthawk224's Avatar
    Jun 2015
    Gilbert, AZ
    60
    1) Put me well on the road to being a "pool snob."
    2) Put me in charge of the chemicals in my pool and although not perfect yet, I have the tools and the knowledge to get there.
    3. Just went outside to check things, test, etc., and noticed the pump was running, but no water was flowing. Did I panic? A little. Then I shut off the pump and started researching what could be wrong and texted the fiance we may have a moderate pool issue here. Taking the simplest possible fix, I primed the pump with water in the basket filter area, did a little magic pump dance (quickly), and turned the pump on. It worked.
    Fiance is planning to take it apart this weekend because I think the shaft seal needs replacing, it has been leaking a little for a while, and he is more of a mechanical fix-it guy than I am. I am planning on using the breaker-off period to get into the big filter and rinse out the cartridges and get familiar with it. It was cleaned well in June by the pool guy friend, but now I want a crack at it..
    See? A little knowledge, a vast potential knowledge source at my back, and a little confidence. Look what you all did...
    ~11,250 gallon, in ground, Pebble-Tec finish, Hayward SwimClear cartridge filter, Hayward Super II pump, Hayward bottom vacuum NaviGator (I call him Fred), waterfall feature, TF-100 Test Kit.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: What the TFP Method Has Done to Me
    Feels great doesn't it, to be in control?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Yeah,
    its a curse I tell ya! A curse!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    HA! Good stuff!
    Aug 2014
    Northern IL
    4,615
    TYBP
    zombiejeep's Avatar
    Jun 2015
    Nebraska
    39
    Ditto!
    21' Revelation AGP ~10,500 gal, Pentair SD60 Sand Filter w/ 1 1/2 HP Dynamo Pump, TF-100 Kit
    Installed 07/25/2015 with city water.
