Thread: auto pilot warning no salt
    I have a autopilot dg220 with sc48 cell. Warning light flashing cell off needs 775 lbs salt. shows zero minerals. Pool salt is 2700 tested. My tri sensor is showing temperature and flow sensor working.I have cleaned in muratic acid and water has fixed temp and other warnings in the past. Is my tri sensor bad or do i have other problems. This morning all working fine my chlorine 3.5 PH 7.4 ta 100 ch 200 stabilizer 40.
    18x36 in ground vinyl liner. Salt water Auto pilot DG 220 with SC 48 Cell.
    Hayward super pump with EC65 DE Filter.
    30,421
    Re: auto pilot warning no salt
    Your post is difficult to decipher.....is everything working OK now?
    no still showing no salt
