Thread: Polaris 480 pro
    Aug 2015
    Farmingdale, Ny
    1
    Polaris 480 pro
    My Polaris has been working all summer. It is hooked up to booster pump. Had to replace entire SW generator and when I turned the Polaris on it bubbles from the vacuum and surfaces many times not sucking up any debris. Any ideas?
    Casey's Avatar
    SW PA
    10,446
    Re: Polaris 480 pro
    Welcome to TFP. So sorry you are having issues since replacing your SWG.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: Polaris 480 pro
    did you change the plumbing schematics when you installed the new SWG? it sounds like you have introduced air into the system which then blows into the booster pump then into the cleaner, builds up inside the cleaner bag and makes the cleaner float.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
