Results 1 to 11 of 11
Thread: Polaris 280 problems
    Could this be the problem why my 280 is moving so slow or not moving at all . when I bring it out the water it does not have any rpms
    Casey's Avatar
    SW PA
    10,448
    Re: Polaris 280 problems
    Certainly looks like a problem. I don't know if it's your contributing factor to it not working but that doesn't look good.
    You got any other ideas?
    https://vimeo.com/135764853 it will not go any faster
    Apr 2013
    Sacramento, CA
    2,769
    I'd look at the gears. Are they stripped when you pull it from the pool do the wheels move freely? Look for something jammed in the wheels.
    Is your pump working?
    Is the pump supplying a strong stream?
    Quote Originally Posted by gwegan View Post
    Wheels move freely, no jams, pump works fine and the flow is fine. I checked the hose, I checked the gears, I changed the pressure valve also
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Try removing the relief valve and replace it with a plug. Several people including me have had to do that to get the cleaner to travel as fast as it should.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Quote Originally Posted by stev32k View Post
    Ok I will try it
    Thanks
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Polaris 280 Troubleshooting | Pool Supply Sales
    Read a few of these and see if they help. I recently replaced my back-up valve and the whole feeder hose and for good measure, the float. I also replace the tail.
    You might get yourself a rebuild kit and you can really learn the guts of the 280.
    The wheels are supposed to turn 28-34 rpms. Faster or slower is a problem. So mark a wheel and then time it. You may need to adjust the restricter in the line. It comes with a blue and red one. Or you may need to remove it. It all depends on the booster pump you are using. I have the Polaris PB4-60, which is 3/4 hp I believe and my feed line is 1". The pressure relief valve has the blue restricter in (the smallest opening I think) in order for the 280 to have the correct rpm range for my set up.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
